Results 1 to 10 of 11
Thread: Edison Pens
    Melbourne, FL
    472
    Edison Pens
    Couple of Baron GoldTi Edison Pens.
    The engraving on the box tells the story.
    Anybody from Ft Myers area that might have a lead on where I can get another piece of this Morton Bay Fig Tree?
    It sure smells sweet when turned and I love to make pens with a story behind the wood.
    11,833
    Neat. Truly a heritage pen.
    Red Deer, Alberta, Canada
    618
    What a beautiful keepsake!
    Great job on the turning, as well!
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Jul 2007
    DSM, IA
    5,719
    Peter, very unique indeed! Well Done!
    Reminded me of Bill G. getting some wood from a tree at the White House. Wonder what ever happened with it?
    My Website
    Nice looking pen, and a great story to go with it!
    That's a great pair of pens with an even better story to go with them. Very nicely done, Pete.
    Mason Michigan
    455
    Great Pens Pete!
    I took my 5th grade class to Greenfield Village in Dearborn MI yesterday and a big part of the village is Thomas Edison's complex. They brought it board by board from Menlo Park NJ.
    "Small Change got rained on with his own 38"
    Tom Waits
    Melbourne, FL
    472
    Pen Turning
    Thanks for all the nice remarks.
    I really posted this in response to the recent post that we are getting more off topic posts than woodworking posts.
    I make pens all the time but seldom post. Next to some of the beautiful items many of you make my pens are just a small side note of another item that can be done on a lathe.
    I have recently started turning pens without using the standard pen mandrel with shaft. I like the method as it is much more accurate. If I get some pictures I will post some info on it.
    For now I will say it is done with very accurate bushings which have a 60 degree cone in them. They do Not have a thru hole for a shaft.
    Place the bushings in the pen tube (they fit so good that they act as a little air piston), put a 60 degree center in both ends of your lathe. Live on one, dead on the other. Snug them up and turn away. The friction fit of the dead center is enough to drive the turning.
    11,833
    Pete, I am a strong proponent of the 'no mandrel' method for turning pens. I do use the standard bushings. Where do you get your special bushing?
    Melbourne, FL
    472
    From
    John Goodin
    over at Penturners
    He makes very high quality bushings.
    He also has a plastic set that are about 0.005 undersize to use when finishing so as not to get metal contaminates onto the wood. CA also is removed easily from the plastic.
  1. Pens, pens, & more pens!
    Last Post: 04-23-2012, 06:18 PM
  2. Pens
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 01-08-2012, 05:35 AM
  3. pens
    Last Post: 11-26-2008, 05:43 AM
  4. More pens!
    Last Post: 11-05-2008, 10:28 PM
  5. Craftsman: Edison Idea?
    By Travis Johnson in forum New Tools
    Last Post: 03-21-2008, 06:52 PM
