Results 1 to 7 of 7
Thread: Optimum Blade Type For Milling Cove Molding On A TS
    Fredericksburg, VA
    161
    I was hoping to get some information about what would be the best blade to use when milling out wide (4+ inches) cove molding on the table saw? I currently have a Forrest WWII and the Freud LM72R Heavy Duty Rip blade. For this operation, would it be best to use a blade dedicated to ripping, or crosscutting, or is a combination blade (like the WWII) OK, as well?
    Thanks very much for any help!!
    - Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    keith, i`d use whichever one has the heaviest plate. thin kerfs don`t do well with side loads. if both are heavy then less teeth is easier on the saw.
    Sep 2007
    Central (upstate) NY
    1,457
    If the smaller blade size would still give acceptable results I would put on the two outer blades of the stacked dado set just for extra rigidity.
    Does anyone else know if a TCG or ATB tooth type would give a difference in the quality of the cove surface?
    Apr 2008
    smithville,tx.
    141
    cmt-makes a 7"-diameter with six cutters -it' at least a 1/2"thick plate-woodcraft sells the set with six router bits for around $400.00-just the table saw cutter is around $200.00,they work better than using a saw blade.
    rounding off the sharp corners
    alex
    Southern Louisiana
    947
    i would go with thicker plate also. i'd also use the one with less teeth to do most of the work, then maybe try to get a cleaner cut on the last pass with a blade that has more teeth. sanding those saw marks out was a bugger when i made mine. used some 60 grit on my ROS to get the marks off then used a lighter grit to finish it.
    if you got 200 bucks the piece by cmt would be nice. i think you can read about it on woodshopdemos.com
    good luck
    Apr 2008
    smithville,tx.
    141
    a goose-neck scraper sharpened right works well to get the saw marks out-also when you get to the last few cuts -take six passes instead of three.
    rounding off the sharps corners
    alex
    Austin, Texas
    1,448
    The scoring marks of an ATB blade like the WW II leave a lot of scratches. A rip blade with raker teeth does a smoother job.
    On the other hand, since I went to my current big saw, I no longer have a rip blade, and the WW II works fine - just some extra sanding or scraping.
    Charlie Plesums, Austin Texas
  1. Milling an Oak
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 11-18-2014, 02:08 AM
  2. Slide top cove boxes
    By michael stafford in forum Flatwork Project Showcase
    Last Post: 11-14-2014, 10:12 PM
  3. Method or tooling to do a cove cut on the inside of a desk leg.
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 06-23-2011, 05:13 PM
  4. Which blade material type?
    By Steve Southwood in forum Neander Woodworking Q&A
    Last Post: 06-04-2011, 01:49 AM
  5. Milling Around
    By Don Orr in forum Lathe Project Showcase
    Last Post: 03-05-2010, 05:08 AM
