Results 1 to 9 of 9
Thread: Challenge: The Fourth
    SE Minnesota
    2,524
    Fancy a new SketchUp challenge? How 'bout a reeded turning for a bed post like 'at?
    Shave and a haircut anyone? Great fourth challenge. Keep 'em comin'.
    Qualicum Beach, Vancouver Island
    103
    Hmm. Tricky. The basic turning ought to be simple enough. The reeeding though... hmm. How about using the line used for the profile as the path for followme with a suitable shape, then rotate/copy as required, intersect with model, delete unwanted bits?
    So do I type something witty here?
    Lima, NY
    53
    OK, I got it this far then I tried to do a test intersect w/ model and then a follow-me to cut the flute but it wasn't coming out correct. Ron
    SE Minnesota
    2,524
    Ron, here's a hint. Copy the profile before you run Follow Me. See Tim's comment. He's right on.
    Cedar Park, TX
    320
    I fiddled around with this one a bit. Made a circle then did single profile of a reed into one "corner" of the circle, rotate copied it to the other 23 corners and deleted the segment ends (exploded the circle before doing the reed) then welded the whole thing. Did a profile of the shape on a plane passing through the center of the circle and marked off incremental lines. Scaled around center to make the circle the size at the base of the profile, push/pulled to the first increment line, scaled the top surface to the profile, push/pull, scale . . .
    Probably not the quickest way, and I didn't do the stuff on top passed the reeded section. Dumped it when finished because it was on the work PC.
    Jerry
    SE Minnesota
    2,524
    Jerry, if I followed your description your method does sound like some extra work. Take a look at the following image and description. I ommitted the rest of the spindle for this.
    #1 Is the profile from this section of the spindle. The profile was traced from an imported image copied from a PDF file. The original profile was at the location of #5, the turned spindle. I copied the profile over to position #1. Had I been doing this for a model and not for a tutorial, I'd have only made the one copy.
    #2 Both ends of the outer edge of the profile were extended a bit. The length of the extension is not critical but you need to make it long enough that the reeding profile will extend fully beyond the ends of the turning. The profile will become the Follow Me path. I drew the reeding profile at one end. It is important to draw the profile so that it is perpendicular to the first segment of the path. I also added a circle perpendicular to the centerline of the profile. The circle's center will be used for the center of rotation later. It is easier to draw that while the centerline exists. I could have used guidelines to identify the center as well. I just happened to have the Circle tool active because I was using it to create the path for the turning.
    #3 I've deleted the unneeded stuff from the profile.
    #4. After running Follow Me on the profile of the reeding, I selected the entire extrusion and made a radial array with the Rotate tool.
    I didn't show the last few steps but they are easy enough to follow. The extrusions were moved over so they are centered on the turning. Then everything is selected and Intersect with model is run. Finally, the waste is deleted and face orientation is corrected as needed.
    When starting this, it is a good idea to move the copy of the profile a known distance. This will make it easier to move the reeding extrusions back so they are properly centered.
    30,002
    Thanks for another challenge, Dave. This one's ahead of my current skill level, but once again it's something I'll be able to come back to later (when I have more time) and walk through the steps you've outlined.
    103
    Quote Originally Posted by Dave Richards View Post
    I *was* ? Cool! I feel so..... validated. Of course, I'd feel even better about it if I had actually done the model.
  1. Fourth in a series...
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 07-19-2015, 10:40 PM
  2. May the Fourth be with you...
    By Art Mulder in forum Off Topic Discussion
    Last Post: 05-06-2015, 12:30 PM
  3. May the fourth be with you
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 05-05-2014, 04:37 PM
  4. May the Fourth....
    By ken werner in forum Off Topic Discussion
    Last Post: 05-04-2010, 10:08 PM
  5. Happy Fourth of July .....
    By John Bartley in forum Off Topic Discussion
    Last Post: 07-04-2007, 08:59 PM
