Results 1 to 2 of 2
Thread: homemade bandsaw handcrank tensioner
    Sep 2007
    Central (upstate) NY
    1,457
    With a little help from a machinist friend I whipped this together tonight.
    My friend had some spare stainless tubing that I used for the swiveling handle - I was going to use some spare 1/2" copper pipe. I threw a little caliper grease into the handle bit - just in case I get smokin' with the crank.
    It is a lot better than the little knob that didn't clear the top of the saw. And I spent less than $5 on it.
    My friend helped with the bending of the threaded rod by supplying an oxy-acetylene torch. If I were to do this again I would have a bucket of water handy to quench the bent metal in while it is still cherry hot to retemper it to hardness.
    Still, it works.
    3,134
    Looks like a very cranky set up to me. Should work just fine.
  1. Homemade Colejaws
    By Rich Soby in forum General Woodturning Q&A
    Last Post: 10-19-2011, 03:50 AM
  2. Carter quick release bandsaw tensioner?
    By Wes Billups in forum New Tools
    Last Post: 01-08-2008, 05:10 PM
  3. Shop Built Bandsaw Tensioner?
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 10-16-2007, 02:30 AM
  4. Homemade burner
    By Joe Tonich in forum Turning Tool Questions and Show & Tell
    Last Post: 10-12-2007, 07:43 PM
  5. Homemade splitter
    By Alan DuBoff in forum Old Iron
    Last Post: 01-31-2007, 11:22 PM
