Results 1 to 10 of 12
Thread: more band saw questions
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    I just received the official approval from the controller of my finances(my wife) that I could buy a new bandsaw. I'm considering the following two machines
    http://www.grizzly.com/products/G0457/images/
    http://www.grizzly.com/products/G0555X/images/
    Does anyone have experience with either of these or are there any other recommendations within the same price range.
    I want to start making bandsaw boxes and my present 14" Grizzly is 10 years old and just doesn't have much left.
    Thanks for any and all input
    Jiggs Elphison
    Floydada, Tx
    1,941
    If you have that kinda money, I would look at ther 17" model(G0513). I have this one and love it. This would give you larger platform for cutting larger peices. Plus you would have a few bucks left over for some over thing.
    I'll second the G0513. I have the 513X and am very happy with it.
    Sacramento, CA
    1,367
    I'm with these two ... if yer upgrading, ya might as well UP grade
    Jason Beam
    Sacramento, CA
    11,833
    There is good reason why the Grizzly G0555 is (claimed to be) the #1 selling bandsaw in the world. Mine has performed perfectly, almost daily, for seven years. The 'X' has additional features. I'm not familiar with the G0457 but the 2 hp indicates it might be better suited for resawing. My only regret is size limitations. I can't reduce large hunks or logs to usin' size with mine. A 17" would be the tool for that. So far, I have resisted putting a riser block on mine as it is my concern that it might overtax a machine that wasn't designed originally to make 12" cuts. I dunno, that's my thinking. Many use the riser happily. Bottom line, you won't go wrong with either.
    Apr 2008
    170
    Bandsaw
    Thanks to all for their recommendations on the Bandsaw - I'm accepting the four choices and I'm orderinh the 17" 513. I'm doing this before the wife changes her mine.
    I'll let you now what happens when I receive it. Thanks again!
    5,322
    Quote Originally Posted by Jiggs Elphison View Post
    Thanks to all for their recommendations on the Bandsaw - I'm accepting the four choices and I'm orderinh the 17" 513. I'm doing this before the wife changes her mine...
    Jiggs,
    Now that the 17" is on the way, try to make room in the shop for both it and the old 14. I've got a Laguna 16, and kept my old Taiwanese 14" too, and have found that I use both of them quite a bit. The old 14 is fitted with a 3/16" blade, and does the 'light work,' while the 16 usually has a " or " blade for heavier work and the resawing. The combination of the two works very well, plus it saves a lot of blade-changing time.
    Apr 2008
    170
    band saw
    As I mentioned in a previous post I bit the bullet and ordered the 17" Grizzley - It's been on back order and was notified today that it will ship in the next week.
    I also remember some post on this forum recommending a particular brand of blades, but cannot remember the brand or the post.
    I also have been given the OK to replace my old Ridgid Miter Saw. Looking at the Hitachi 8 1/2 or 10" slider. Any comments pro or con?
    Congrats on the upcoming new saw, Jiggs. One popular source for bandsaw blades is Suffolk Machinery. You can call them up and tell them what you want to do with your saw, and they can advise you on what blades would be best.
    Hey Jiggs, congrats on the new saw!
    Are you keeping the old one for scroll work like Jim suggested? That is very good advice, in my opinion.
    Hitachi SCMS, I've got the older C8FB saw, and I love it, it is a workhorse and it is still dead accurate after all these years.
    I really like the new one they have out, with the slider rails up and to the right of the saw, instead of behind the saw, this lets you put your saw station much closer to the wall.
    I just looked at the US Hitachi site, and I only see the compact slider offered in the 10" version
    I also see that they have the newer C8FB2 8-1/2 saw, very similar to the one I have.
  1. Tom and Band Saw
    By Jim C Bradley in forum Old Iron
    Last Post: 03-21-2015, 02:01 AM
  2. Band clamp questions
    By Roger Pozzi in forum New Tools
    Last Post: 12-30-2011, 03:56 PM
  3. Just a little band saw
    By Brent Dowell in forum Old Iron
    Last Post: 08-18-2011, 02:23 PM
  4. In need of a band saw
    By Chris Hatfield in forum New Tools
    Last Post: 11-16-2010, 07:53 PM
  5. Old Arn - Band Saw
    By randy street in forum Old Iron
    Last Post: 08-17-2007, 12:45 PM
