Results 1 to 10 of 20
Thread: Are chainsaws supposed to leak oil?
    My chainsaw leaks bar oil when it sits around out of use. Is this normal? I'm not sure where the leak is coming from.
    George
    Tokiwadai, Japan
    2,882
    Quote Originally Posted by George Conklin View Post
    Where is the leak at? Around the fill cap? Near the gear? If you clean the saw up after it's been unused for a while, does it leak again? Can you clean it well, put it of clean paper (white paper towels) and see where it's leaking?
    G
    My 31 year old Mac leaks a little where the chain oiler meets the bar for the chain. It seems do it for a short period of time after I use it. Then things are okay.
    Ken
    810
    George,
    A suspected oil "leak" is common on saws, but it may not be an actual "leak" (as in a defect).
    If the saw only shows a leak after you've used it but the bar oil level in the tank doesn't go down, then the "leak" is probably the residual oil from the bar and chain dripping off the bar.
    If the saw leaks oil all the time and the oil level in the tank does go down, then there are a few possibilities:
    • The tank or an oil line is leaking
    • The cap is leaking
    • The tank vent is plugged and the tank is forcing oil thru' the system from pressure building in the tank
    To check for actual leaks quickly you can remove the bar and chain, clean the saw very well, drain the oil tank, flush it well and then refill it with a blend of mostly gasoline coloured with a bit of chain oil. Set the clean dry saw on a cardboard and watch it for a few days. Gasoline is very quick to find small cracks and a leak should be apparent quickly.
    If you don't see any leaks, you can drain the fuel/oil mix from the oil tank and refill it with chain oil. reassemble the bar and chain and test cut. When you're done set the saw on a cardboard and watch for oil to drip from the bar over the next few days.
    Tank vents are in different places depending on the saw. If these tests (above) don't solve it, let us know what make and model of saw you have and we can advise further.
    cheers for now
    John
    New Zealand
    97
    A small amount is normal, thats just whats sitting in the chain oiler mechanism when you switch off. The bar has no oil seal where it matches up to the oiler passage, so some seeps out. Sit the saw on some cardboard to catch the drips.
    If you get an Exon Valdez type oil slick under the saw, then you have a problem, maybe a crack in the oil tank or oiler mechanism.
    Ian
    Great info guys, the only thing I can add is, "Did you buy new chain oil recently...? if so, did you get electric chainsaw chain oil by mistake?" The electric chain oil is a LOT thinner than regular chain oil, could be a factor.
    Goodland, Kansas
    4,834
    Agree with the rest. It is probably from your chain oiler. Nothing to worry about unless it is a large amount.
    Bernie W.
    lutefisk capitol, USA
    485
    Does it have a Harley motor? Both my gas and electric ones drip oil from the chain oiler.
    Thanks for all of the replies.
    It's not leaking around the cap and it is a lot of oil! All of the oil in the tank will leak out over time.
    I guess it's time to take her into the shop.
    Thanks again.
    George
    810
    This symptom really sounds like a plugged oil tank vent. It could be a leaky gasket or a cracked tank, but plugged tank vents are very common, far more common than actual "leaks" from defects.
    If you want to take a bit of time to look at it before it hits the shop, get me the make and model of the saw, and I'll tell you where the tank vent is and how to clean it.
  1. Was Supposed to be a Box
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 07-26-2015, 06:15 PM
  2. It' snot a ceiling leak
    Last Post: 12-24-2010, 07:28 PM
  3. Live Streaming Cam from BP Oil Leak
    Last Post: 05-27-2010, 11:22 AM
  4. electric chainsaws
    By Carol Reed in forum Turning Tool Questions and Show & Tell
    Last Post: 02-25-2010, 11:53 PM
  5. Really, it's not supposed to snow here!
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 02-06-2008, 02:47 PM
