Results 1 to 8 of 8
Thread: Pocket Door Question
    Lake City, Florida
    498
    I have a pocket door going to the laundry room that's been damaged and I want to replace just the door -- the rest of it is fine. Problem is I can't figure out how to get the door off the tracks It will not lift straight up and off -- the upper rollers are too fat come out of the tracks.
    There must be a way to remove the door without busting the wall open -- HELP!
    Tony, BCE '75
    most doors are accessable after you remove the head piece of casing.
    without knowing what hardware was used i can`t offer any more advice
    30,017
    You might try checking just inside the wall for an opening that will allow the rollers to lift out. My last house had a pocket door, and there was an opening in the tracks just inside the wall that would fit one roller at a time. In other words, you rolled the door into the pocket, lifted one edge out of the track, then slid the door (on a single roller) to where the door was closed, then you could remove the other roller.
    The Heart of Dixie
    4,268
    Just to add to the confusion, mine hang on the rollers. You have to remove a clip and then you lift the door up and remove it from the rollers.
    Custom built boats and Kits
    Houston, Texas
    2,323
    Any chance of seeing several pictures of the hardware and the hanging situation? We can make it work Tony, just don't bust out anything yet, maybe later!
    Shaz
    You may have segmented tracks, one of which could be unscrewed when the door is retracted.
    Please join me. Register now.
    Shaz
    Here is how
    Lake City, Florida
    498
    Thanks All -- I GOT IT !!
    After removing the head piece on the casing (THANKS TOD!) I saw it. The rollers do not come off, but by loosening the upper nut the 'hanger' slides off through a slot on the bracket attached to the door.
    Sorry, the pic is BAD -- but you should get the picture.
    Thanks All - I appreciate the leads. And you were right Shaz, didn't have to bust anything out
    Tony, BCE '75
    The one I installed in our basement bath has levers that lock to the roller assembly. There's more than one way to skin a cat!
    Glad you go it Tony!
    Ken
    Lake City, Florida
    498
    Quote Originally Posted by Ken Fitzgerald View Post
    I was so focused on lifting the rollers off the track, I didn't look for anything else!
    Tony, BCE '75
  1. pocket door problems - RESOLVED!
    By Carol Reed in forum Carpentry and Construction
    Last Post: 11-24-2014, 03:08 PM
  2. Pocket door and electrical in 2x4 wall.
    By Brian Altop in forum Carpentry and Construction
    Last Post: 05-06-2011, 03:31 AM
  3. Newby question and pocket hole joinery
    By Leo Wirtz in forum General Woodworking Q&A
    Last Post: 02-07-2011, 06:36 PM
  4. Kreg Pocket Screws and Bits question
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 01-15-2009, 12:37 AM
  5. Pocket Door Track Recommendations
    By Jeff Wright in forum Carpentry and Construction
    Last Post: 06-26-2007, 04:10 PM
