Results 1 to 10 of 12
Thread: Bandsaw
    Goodland, Kansas
    4,834
    Bandsaw
    Well the 10" Delta bandsaw I use for cutting lidded box, ornaments, pen's blanks, etc. bit the dust tonight. The shaft sheared right at the rotor/armature. I got on the net and checked at the Delta website and they said the motor was $157 so I called. Kinda bummed me out that the motor was that much and I paid $129.99 for the saw. So I called them. The told me it was discontinued with no replacement. They said when B & D took them over they were not having any parts made for those and several other pieces. I was hot. So I asked about dealers close to me in Kansas or Colorado. Cheapest one I could find was $195. Would not even talk about it. I really liked this saw but can see paying almost twice for a motor than what I give for the saw.
    So one question I have is does anyone have any idea's about another 10" bandsaw? Like I said mostly for box blanks and pen blanks. The wife also uses it like a scroll saw and likes it better than the scroll saw I got her. No I don't need a big one as I have the Grizzly Ultimate with riser. I just get tired of switching blades to do small jobs. I really like the 10" but have a hard time except for Craftsman or Rikon which are one in the same. Only difference is the Rikon has a aluminum table with no fence and the Craftsman has a cast iron table with a fence. Reviews on it out of 56 was 4.1. Any suggestions? Thanks
    Bernie W.
    15,806
    Is the busted saw a direct drive motor?
    Is it possible to replace the motor with something else?
    Pictures please
    Just did some looking around and I found this........
    << Linky Pic
    Ryobi 10" bandsaw
    It looks like it gets good marks, in that review, also in >> THIS << review, but finding one for sale seems to be a problem
    Of course you could buy your LAST small bandsaw and get an Inca 340
    One for sale in LA >> HERE <<
    Good luck!
    Floydada, Tx
    1,941
    Does grizzly still make there baby 9" model? If so, that is a great little saw. A fellow ww as one and loves it.
    inca is good stuff!
    Jul 2007
    DSM, IA
    5,719
    My local Lowes has a hitachi 10" on sale for $139 right now.
    My Website
    The Heart of Dixie
    4,268
    Bernie, is this just a standard motor? Do you have to buy it from Sears?? Often they are standard motors so you might find something that will fit.
    Custom built boats and Kits
    Goodland, Kansas
    4,834
    Thanks for the suggestions. I forgot to mention the motor is direct drive. The pulley the blade runs on mounts directly on the motor shaft with a slot key. The motor mounts directly to the frame of the saw with 3 bolts. I will do some more research but like I said I only paid $129 for the unit and don't want to spend a bunch of money trying to fix it. I would buy a 12" one but it needs to go on my bench so has to be a bench top unit. I just do not have room for a floor model.
    Bernie W.
    5,317
    Quote Originally Posted by Bernie Weishapl View Post
    Thanks for the suggestions. I forgot to mention the motor is direct drive. The pulley the blade runs on mounts directly on the motor shaft with a slot key. The motor mounts directly to the frame of the saw with 3 bolts...
    Bernie,
    What's the shaft size, and what is the motor rpm? If the shaft size is a standard, like 1/2" or 5/8", and the speed is somewhere around 1000~1200 rpm, then you might be able to adapt a more common off-the-shelf motor to it.
    Note: the most common motor speed is 1725 rpm, and that would give you 4500 feet per minute (fpm) blade speed, which is a bit fast. 3000 fpm is the commonly recommended speed.
    Goodland, Kansas
    4,834
    Well contacted a couple of motor companies to see about getting a motor or seeing if they would have a motor that would fit. Grainger had one that would have to have the mounting modified but still wanted $118 for one close to the 1125 rpm on the machine now.
    Anyway I called Sears in Colby about 32 miles from us and he said he had sold 4 of the 21400 10" bandsaw and gave me the names. One of the gentleman I called told me to come over and I could use his to see if it fit my needs. So I did. It has bearings top and bottom for blade guides and cast table instead of aluminum. Comes with fence and miter. Resaws 4 5/8". We resawed a piece of 1 X 3 oak just a hair under 1/8" and it did a really nice job. He told me to get a good timberwolf blade which I use anyway. It was quiet and no vibration.
    So I went to the Sears store and bought one. It was on sale to boot from $189 down to $149. Since this was a franchise store they had to order it but no big deal.
    Thanks for all the suggestions, help and kind words.
    Bernie W.
    Jul 2007
    DSM, IA
    5,719
    Bernie, congrats on the new bandsaw...went to sears.com to take a look at it and its sold out there too. Hope yours arrives very soon so you can get back to cutting.
    My Website
  1. Bandsaw Box
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 03-25-2014, 07:52 PM
  2. bandsaw box
    Last Post: 06-29-2009, 01:06 PM
  3. BIG bandsaw
    By Dale Johnson in forum Old Iron
    Last Post: 05-17-2009, 03:28 PM
  4. My new Bandsaw....
    By Ned Bulken in forum New Tools
    Last Post: 04-13-2008, 05:14 PM
  5. Need a bandsaw bad!!!!
    By Chuck Hanger in forum New Tools
    Last Post: 12-12-2007, 01:05 PM
