Results 1 to 5 of 5
Thread: clear finish on Purpleheart?
    39.92*N x 86.01*W
    112
    What would you recomend? Obviously, I don't want anything to mess with that gorgeous purple tone - but I want the wood protected.
    If it helps any, this will just be something decorative, hanging on a wall.
    If anybody has suggestions, I'm all ears.
    -Kevin in Indy
    "Heroic? He fell off his bloody Aeroplane!"
    30,014
    I'd think pretty much any of the clear wipe-on finishes would work fine. I'd probably use Minwax Antique Oil finish, just because I already have some on the shelf in the shop. Wipe-on poly, or one of the tung oil blends should also work great.
    If in doubt, try the finish on a few scraps, being sure to also follow the same sanding routine as on the piece you want to finish.
    lutefisk capitol, USA
    485
    Get something with UV inhibitors or blockers. Purpleheart will turn a very rich brown over time. I have heard that placing it in the sun will return the purple, but can't say for sure. Check with this guy and see if he has any advice on his site. www.woodturner-russ.com.
    Using with an oil based finish will turn the shade to a cranberry color. If you want to keep the purple "grape" color, use a water based finish. There is nothing that will keep purpleheart from browning over time, but if the wood is sealed with a finish, kept from direct sunlight, it is a very slow process. It holds it's color much longer than paduak, sp?
    Rio Rancho, NM
    1,417
    We've had very good luck with purpleheart by clear-coating it with lacquer. Two or three coats. I have some purpleheart accents on some of my furniture, and it's still a nice purple. Granted, it doesn't get a lot of direct sunlight, but my living-room tables are four years old and still as purple as the day they went into the house.
    Nancy Laird
    dandnspecialties@msn.com
  1. Replies: 9
    Last Post: 09-14-2015, 04:06 PM
  2. Finish for Purpleheart?
    By Earl Rumans in forum Finishing School
    Last Post: 02-05-2014, 10:47 PM
  3. re-purpling purpleheart
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 07-20-2010, 01:03 PM
  4. Purpleheart
    By Peter Lyon in forum General Woodworking Q&A
    Last Post: 12-21-2009, 01:29 AM
  5. Purpleheart & Maple
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 04-09-2007, 01:17 PM
