Results 1 to 3 of 3
Thread: negative pressure room
    17,477
    well i tried my idea out in the finish room which i had gathered from a forum tip but i got the exhaust part wrong.... i have more air coming in that can get out.. i have a 3 speed furnace fan blowing in on the slowest setting but i need to get that bad air back out down low.. i think i can get that with another furnace fan but the little helper fan i had was'nt enough.. i close the door and it goes out under the door because it can get out elsewhere i can help it out alot if i open the window but that will cause the fumes to rise again and want them to stay low if can out off my smeller any ideas from the engineers out there...
    The Heart of Dixie
    4,268
    Add vents?
    Custom built boats and Kits
    17,477
    VENTS
    any suggestions on how to vent without having the winter air blow in???? that was why i thought i could blow it out therefore having less winter access...saw what marty has but that thing will suck me out
  1. Negative rake scrapers?
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 08-02-2015, 11:15 AM
  2. Negative Rake Scraper
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 11-11-2011, 02:23 PM
  3. Negative Rake Scraper
    Last Post: 01-09-2009, 02:00 AM
  4. about negative rake blades
    Last Post: 06-25-2007, 12:43 PM
