Results 1 to 9 of 9
Thread: What blade? 12" CMS
    Livermore CA (SF Bay Area)
    51
    What blade? 12" CMS
    I loaned my Delta 12" CMS to a friend to cut a bunch of base moulding (plastic and wood) for his bedroom, halls and bathrooms. When I got it back, the blade had a lot of white plastic on it, so I spent an hour or so cleaning it, only to find about 8 carbide teeth missing. I am sure he didn't do it cutting base and cove moulding; the blade is one I have had in the saw for a long time. Must have happened on my watch but it was not something I noticed until I cleaned it.
    Question is, what blade do you recommend (# of teeth, brand, etc.)? I just use the saw every once in a while when I am cutting baseboard or crown moulding.
    Thanks.
    Warren
    Houston, Texas
    2,323
    Quote Originally Posted by Warren White View Post
    Thanks.
    Warren
    Hi Warren ,
    Sorry about your blade, it does happen. It costs about $3.50 a tooth for repacement carbide to be put back on a blade down here.
    I would get an 80 or a 100 tooth, for a really smooth cut on your molding. Change over to another blade if you loan it to someone else. I have heard Amana has a good product. Good luck. I'm not sure of the tooth set but maybe one of the other folks will step up and share.
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    lutefisk capitol, USA
    485
    I put on an 80 tooth Freud on my 12". I made the mistake of loaning out one of my power tools and getting it back damaged, so now I go with it or it don't go.
    Charlotte, NC
    1,487
    Freud on mine, I think it's around 80 tooth. Diablo from the Borgs. It's been working quite nicely for quite a while, leaving a nice smooth cut.
    Floydada, Tx
    1,941
    The one I have used is the Forrester chopmaster. It leaves a nice clean cut. I would take the old blade in to see if it can be saved. If not, then you can make a shop clock out of it or have it painted for wall art.
    May 2008
    Rio Rancho, NM
    5
    Sorry about your blade Warren. If you use your CMS for mostly finish/trim work the 96 tooth Freud Diablo with -5 deg hook angle is the best blade and at HD for $65. Zero to -5 deg hook angle is best blade for CMS.
    Gerry
    http://www.homedepot.com/webapp/wcs/...3+90087+524421
    51
    Thank you!
    I really appreciate all of the replies. I hadn't thought about having the teeth replaced, so the blade is gone. I will start looking for a replacement with the advice you have given.
    A great place to learn....
    Warren
    Fort Washington, PA
    180
    Woodworker II, their standard combo blade (1/8")... once I tried that, I never looked back. Little pricey, but does great both rip and crosscut, a premium blade that delivers in my humble opinion. Eventually sent it back to get sharpened, bought a second while that one was away so I always have a good sharp blade in reserve in case I hit something and chip a tooth or what not.
    Build it Break it Fix it ...repeat
    Bloomington, IL
    127
    Dave, it is for a CMS so the WWII in your tablesaw is probably not for him.
    I have a Hitachi thin kerf and it works really good. Also bought a forrest 12" Chopmaster but have not put it on yet. Still using the Hitachi.
  1. 16" Ras Blade
    By Al killian in forum Old Ads
    Last Post: 04-27-2011, 06:30 AM
  2. 10" table saw blade
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 06-24-2009, 05:43 AM
  3. 10" Tablesaw Blade, 1/8" kerf, Flat-top Grind
    By jim crockett in forum General Woodworking Q&A
    Last Post: 08-22-2008, 01:39 PM
  4. "Dado Blade Storage"
    By Lary Grassmeier in forum General Woodworking Q&A
    Last Post: 08-04-2007, 08:22 PM
  5. Free 4 1/2" diamond blade
    By John Dow in forum Old Ads
    Last Post: 05-10-2007, 01:04 AM
