Results 1 to 10 of 12
Thread: Mallee Burl Bowl
    Mallee Burl Bowl
    This is a piece of mallee burl I picked up at Rockler a while back. I had a hard time deciding on a base I liked...this maple one is about the 5th or 6th one, but I think I'll call it done. The color seems complimentary to my eye. (Still haven't glued it in place yet, though.)
    The top is about 13" x 9", and it stands about 3 1/4" tall. The bowl itself is about 5 1/2" wide. This has my standard Antique Oil followed by lacquer finish, with the cut parts buffed. The cut face of the blank had been dipped in paraffin wax about 1" or 2" deep, so I had some work getting the wax out of the nooks and crannies of the backside. In the end, a heat gun and paper towels got it handled.
    Figured I'd post a whole boatload of pictures, and let you guys sort through them.
Name:	Bowl 047 - 01 800.jpg
ID:	20914 Click image for larger version.
Name:	Bowl 047 - 02 800.jpg
ID:	20915 Click image for larger version.
Name:	Bowl 047 - 03 800.jpg
ID:	20916 Click image for larger version.
Name:	Bowl 047 - 04 800.jpg
ID:	20917 Click image for larger version.
Name:	Bowl 047 - 05 800.jpg
ID:	20918 Click image for larger version.
Name:	Bowl 047 - 06 800.jpg
ID:	20919 Click image for larger version.
Name:	Bowl 047 - 07 800.jpg
    I didn't have a lot of wood to grab with the chuck. This stuff was HARD, and my Forstner bit was dull. I had things smoking by the time I got the hole this deep.
Name:	Bowl 047 - 08 800.jpg
    As always, I'm open to comments, critiques, or suggestions. Let me know if you think the base should stay, and if not, what you'd replace it with.
    566
    Vaughn, this is a beautiful piece of wood and you have done a terrific job of displaying it.
    I have limited experience with turning this kind of burl but let me share what I was taught by someone who turns a lot of them.
    Instead of mounting the burl by drilling a hole in the back for the chuck to expand into he suggests mounting the burl to a sacrificial faceplace made from MDF using wedges and hot melt glue to get the display surface in the correct plane for turning. The sacrificial faceplate should be as large as you can swing on your lathe and allow you to position your blank anywhere within its circumference without having the blank hit the lathe.
    Basically you locate the center on your blank where you want to turn your bowl. Then using the tailstock and three or more hands position the blank against the sacrificial faceplate. Then using a square, square up the face of the blank until it is perpendicular to the ways of the lathe bed.
    Fix the blank to the sacrificial faceplate with lots of hot melt glue and wedges. Obviously the wedges are to help keep the blank face perpendicular to the ways and parallel to the faceplate. You can also screw weights to this sacrificial faceplate to help balance the whole contraption for smoother running.
    I know this may be difficult to understand after reading the crappy explanation I have written but I think you will get the drift.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Thanks for the idea, Mike. I don't know if that would have worked on this one, since it didn't have a good natural foot to set it on. It wanted to list pretty badly to one side. I also thought of screw chucking the face to make a flat foot on the bottom, but it would have wiped out quite a few of the spikes.
    Constantine, MI
    7,892
    Vaughn,
    Looks like it's time for me to renew my congratulatory posting - the one that carries me through 10 of your turnings and helps me avoid having to post the same message for each of your projects.
    Wow! Neat! Way cool! Nicely done! Really sharp! Beautiful! and the ever popular "nice photography!"
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    11,833
    Stunning. But I nearly cried at the thought of all the fine pen blanks that could have made.
    Jul 2007
    DSM, IA
    5,719
    Beautiful Vaughn. Well Done
    My Website
    Sep 2007
    613
    Well Vaughn, Rennie says it all, so for the change I'm doing it in Dutch, verrassend mooi, goed gedaan!!
    Ad
    Goodland, Kansas
    4,834
    Beautiful piece Vaughn. Very nice wood and well done.
    Bernie W.
    Los Angeles, CA
    2,668
    Beautiful wood. Nice job on turning this one. I like the little base that it stands on.
    Tyler, Texas
    336
    Beautiful piece, Vaughn. I happen to like the foot very much as it would have been a shame to turn away any of those pins. That's a neat idea you had and one I will have to use sometime.
    Cody
  1. Cherry burl bowl
    Last Post: 12-14-2013, 06:17 AM
  2. BROWN MALLEE BURL
    By Peter J Hay in forum Lathe Project Showcase
    Last Post: 08-10-2013, 10:26 PM
  3. Septarillion - Red Mallee Burl Turned and Carved
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 09-25-2011, 10:36 PM
  4. Brown Mallee Burl HF
    By Keith Burns in forum Lathe Project Showcase
    Last Post: 11-03-2007, 12:25 AM
  5. Red Mallee Burl bowl - first posted pic
    By doug mcginnis in forum Lathe Project Showcase
    Last Post: 10-08-2007, 02:03 AM
