Results 1 to 10 of 11
Thread: drilling steel
    11,831
    drilling steel
    Not a wood working question.
    I need a 5/8" hole in a piece of steel. I did drill a 33/64th" hole but, unfortunately, it will not work. I'm reluctant to order a $20.00 bit and pay for shipping for about ten seconds worth of drilling to open up this hole.
    I do have a lot of masonry, carbide tipped, drills. Would it be disastrous to use one of those to open up this hole? I don't care if I ruin the bit.
    The Heart of Dixie
    4,268
    ... I don't care if I ruin the bit.
    What have you got to loose then?
    Custom built boats and Kits
    lutefisk capitol, USA
    485
    Any plans for more than the one hole? If I dig deep enough in my "stuff" I know I have one made with a #2 morse taper on it. I just pop off my chuck and put the bit in the press. Let me know.
    11,831
    An eye???
    11,831
    Quote Originally Posted by Dale Johnson View Post
    Thanks, Dale. This is a drill press, not a spinny job. I'll keep that in mind though.
    17,472
    how criticle is this hole? try a rat tail file to make it bigger or take it to amchine shop friend to ream it.. i bet tod could fix it for ya.
    11,831
    I called a retired machinist friend. He said to do it. Go easy, use plenty of WD-40, watch for catches. Worked fine and I still have my eyes. Larn sumptin new now and then.
    30,014
    If you take the chuck out of your drill press, you'll likely find there's a #2 Morse taper up inside there.
    11,831
    Yep. Wasn't thinking that deep. Oh, well, got it done.
    13,360
    I've put a super heavy duty trailer hitch and some belly bar brackets on my F-350 to hold the camper. Lot's of big holes through fairly thick steel at awkward angles.
    Things I learned:
    1) Speed kills (the drill bits)
    2) Keep the bit and hole lubed up with Cutting Fluid
    3) A drill doctor drill bit sharpener can pay for it self in drill bits on one job like that.
    I had a couple of drill bits and found that I could get about a hole and a half. taking sharpening breaks helped both me and the bits get the job done.
  1. Lathe Drilling Jig ?
    Last Post: 02-19-2014, 05:58 PM
  2. Pen Drilling Jig
    By Raymond Sprouse in forum Jigs and Fixtures
    Last Post: 05-26-2011, 10:25 AM
  3. Drilling a lamp
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2010, 03:53 PM
  4. Pen Drilling Ideas
    Last Post: 04-22-2008, 01:14 AM
  5. Lee Valley Drilling Kit
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 11-30-2007, 09:09 PM
