Results 1 to 4 of 4
Thread: help needed
    Born in Rockville Maryland and relocated to Texas in 1997. Mt Enterprise Pol 525 a small but nice pl
    3
    help needed
    I would like to know the height and width of the fence on the Ridgid 2400 and
    3650. I want to make some hold downs that would slide over the fence and clamp in place.
    Thank you
    John
    30,002
    John, the fence from my 3650 is 2 3/4" tall and 2" wide. Mine is very slightly wider at the top than the bottom...2.005" at the top vs. 1.995" at the bottom.
    Hope this helps -
    May 2008
    Bellevue, WA
    38
    TS2400
    The fench on my TS2400 measures 2.010 at the top and 2.005 at the bottom. It s top is 2.756 above the table (note the set up for the fence results in a small gap above the table, that gap is included in this measurement).
    Dick
    30,002
    Richard brings up a good point...my height measurement (which was actually 2.764") was the fence only, and did not include the slight gap between the fence and the table top. I couldn't get that measurement, since my Ridgid fence has been replaced on the saw with an Incra setup. (I dug the factory fence out of the attic in the garage to get the measurements.) Also, based on Richard's measurements, it looks like there's a bit of variance in the width of these fences. Depending on your tolerances, it looks like 2" on the money (and a bit of sandpaper) will get you there.
  1. It Just Needed It....
    Last Post: 02-28-2012, 05:51 PM
  2. Acrylic help needed
    By Rob Keeble in forum Jigs and Fixtures
    Last Post: 02-16-2012, 09:23 PM
  3. Suggestions needed.
    By Toni Ciuraneta in forum Off Topic Discussion
    Last Post: 10-06-2009, 10:55 PM
  4. wood ID needed???
    Last Post: 05-22-2009, 04:46 PM
  5. Suggestions needed.
    By Kevin Reid in forum General Woodworking Q&A
    Last Post: 08-21-2008, 02:25 AM
