Results 1 to 10 of 25
Thread: plywood wastage planning
    Sep 2007
    Central (upstate) NY
    1,457
    Do folks that retain plywood offcuts prefer long narrow pieces or closer to square off cuts? Why?
    This question is so pertinent and ironic.....so understand my reply...
    I prefer to not have plywood cutoffs...As in the 31" by 22" cabinet door I just mis-cut....
    I generally leave my cutoffs as is. In time most will find a use. IF you cut it narrow .....you are kinda stuck finding a narrow use for it. Later if you find a narrow use, you can cut....if you find a wider use....and it fits...you got it....
    Ken
    17,472
    when i built my shop i used alot of osb and saved all the off cuts if they were over 6"wide i have after some time, used alot them up in the inside finish,, still have a few and darn few left..and burned a batch that were 6" by 48" those just didnt find a home but the hot dog fire if you think you can use it and have room save it, after a period of time you need to sort and get rid of them to start again with a new sheet mark
    Sep 2007
    1,457
    I was originally trying to decide what order to use to make my cuts, but have decided to just make my cuts in the order that makes it easiest for me on the main project and not worry about what is left behind. I'd rather have my intended pieces right than have perfect offcuts and bad project pieces. I guess I'll just learn from Ken on this one!
    Thanks!
    Jan 2008
    Lived in Michigan until I retired in Mexico. Build furniture for use. If I need it I build it.
    46
    Mark, most of my cut off will be long narrow pieces because I usually like the grain running the long way on my cuts, I guess on particle board and similiar type the grain direction doesnt matter much. As Larry said most of my cutoffs get used for something, then pretty soon I find out I've used all the ply. plus the kids use a lot of it for school projects and playing around, a very good learning tool for them. Many of the relatives and friends come over needing a piece of ply too. Lately I've been using a lot of it for test staining and spraying, but those pieces are still good for something. Jerry
    http://gschacht.bootlogic.com
    5,533
    Quote Originally Posted by Mark Kosmowski View Post
    Thanks!
    There you go! The project cuts come first, the scrap is just that, scrap. incidentally, you can get a free copy of cutlist which will help maximize your sheet goods usage. it will only allow you to specify 5 'parts', but that'll usually get you in the door on a project.
    I ponied up for the 1st level of product awhile back, so I can do up to 20 pieces per project iirc.
    end result, maximize your layout and have at it!
    -Ned
    Jan 2008
    46
    Mark, I have cutlist (purchased version), I enjoy it very much, but if you have only a project or two to do, a pencil, graph paper workes good for ply layout, and you can see what sizes are left from the graph and where to change any dimensions. Jerry
    I hear what you are after, but the way I design my cuts is to layout in such a way that I can have the sheet precut, at the yard, into manageable pieces a gimped up old WWer can handle in a small shop. Either ripped to a predetermined width or cross cut into a couple of smaller sizes.
    This is an easy task here in this local area as it seems the Lumber yards and Home centers hire trained employees who can measure. But reciently I was at my mom's home and we needed extra slats for her antique bed. So I went to Lowes and wanted 1X3 Furring strips cut to 55" The fellow said "Within 1/4" I took it for granted he could measure better than that and said OK (a CYA answer incase he screwed up) but when he handed me the first two, I measured and they were 54 1/4" I said "I hope the rest are colser than that as these are 3/4" off, not 1/4" He got huffed and then another fellow came by and completed the task to a correct measurement, dead on. (all the while I watched moss grow on his feet as it took so long to complete the task of sawing 6 wood slats.
    This is a problem of not carrying a complete tool array when you go for a visit.
    Back to the Primus of your quary, I save offcuts no matter what shape and store them till I need them or as was suggested, untill winter when a kindling supply is needed.
    Unless it's going to be painted, I plan for the best appearance and let the waste land where it may. I have a bin that holds 4' and less panel scraps in whatever shape they come in and use them as the need comes up.
    new york city burbs
    10,188
    Im in fear if I post my amateurish ways anymore, the powers that be might close my access.
    Why throw out any wood?
    Im not destitute, not poor, but I dont throw out any wood since I started this hobby couple years back.
    Got 3, 4 , 5 inch cutoffs, hey no problem.
    Got some time, nothing to do, make a gift.
    I know its above the real pros here, but I have the advantage of no talent to help me come up with my ideas.
    Mark, everyone has that one person we want to give a little gag gift too now and then.
    Take a few pieces, mitre the ends, make a box, rabbet out the back,find some old glass, (I buy cheap, cheap at garage sales, like 25 cents each, just for some glass), dado out the thickness of the glass, glue it up, take some of those strips of hardwood, like the 1/4 inch strips, whatever, or poplar that you normally chuck in the garbage or use for the fire place.
    Make a mitred faceframe, and boom, get a paint pen, a stencil, make a gift.
    Heres one Im in the middle of, too many things going on, too little time.
    For the guy who has everything. Sometimes, Id put a Bud bottle in there, a lone cigarette, a pack of cigs, adult themes, anything like I put a pack of twinkies in one for someone I knew who had a twinkie fetish and was on a strict diet.(so Im mean, they laughed alot)
    If I have a piece of small chain, I make a tiny looking hammer and attach it, kinda makes it look a bit nicer.
    Maybe it costs me 50 cents for the glass and chain.
    If theres only 3 inch strips, make the same box,but longer and wider, put some dados for shelves, put a faceframe around, great if you have some scrap hardwood for faceframe, only need 1/8 or 1//4 inch, and boom, its a curio box for someone.
    Stain, paint, dont matter. I use whats laying around.
    I know this all sounds silly, but I have yet had anyone laugh or not enjoy the gift, especially since I made it for them.
    (I put a phony Amex gold card in one, for a girl who spends too much, she put it in her office)
    Always best to make the item look suspended in air by attaching it to the back.
    Again, I apologize if this is out of line, I just wanted to show how I use all the ply scraps.
    Attached Thumbnails Attached Thumbnails Tiki 255 (Medium).jpg   Tiki 256 (Medium).jpg
  1. Been planning on making one of these
    By Bob Gibson in forum Jigs and Fixtures
    Last Post: 10-05-2014, 06:44 PM
  2. Not What I Was Planning to Do
    Last Post: 11-26-2011, 10:35 PM
  3. Way out there trip planning
    Last Post: 01-14-2011, 12:40 AM
  4. New Shop Planning
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 10-24-2009, 02:06 PM
  5. Kayak planning
    Last Post: 12-28-2007, 02:57 AM
