Results 1 to 9 of 9
Thread: Waste not want not
    Cornwall, England
    392
    Waste not want not
    I've done a few of these things using offcuts from various places. Sometimes it works sometimes it doesn't. I like the way it allows you to keep a lot of the figuring that would otherwise get turned out.
    Opinions welcome
    The first one is approx 9" long at 4" at it's widest, secoind is approx 5" long & 3" wide. I don't square them up, just plane and sand the edges smnooth. Leave the shape whatever it is. Done a few triangle ones as well, have to watch your knuckles with those as the ghost is hard to see.
    Pete
    Jul 2007
    DSM, IA
    5,719
    Pete, I like the look of these a lot. Simple bowls showing what the log/wood and all of its beauty. Well Done
    My Website
    Los Angeles, CA
    2,668
    Pete, one part of my brain appreciates the simple beauty of the pieces but the other part of the brain thinks that they are kind of unfinished and something more could be done to them.
    Cornwall, England
    392
    Quote Originally Posted by Mohammad Madha View Post
    For the one part of your brain, thanks, for the other...any suggestions, ideas etc more than welcome. I am always open to any knid of inspiration from any source so feel free.
    Pete
    Of the two, I prefer the second one. I think it's the color variations in the wood that appeals to me on that one. I like the 'bowl in a block' concept, but like any other turning, some will be more appealing than others, and you usually won't know for sure until it's done.
    How are you mounting these on your lathe?
    Toledo, OH
    56
    The undulating lines of the second one reminds me of the slot canyons of Utah...nicely done!
    Cornwall, England
    392
    Initially use a screw where the bowl will be and turn as small a tenon as possible on te base. I mount it on the tenon to turn the bowl and plane the base flat afterwards.
    Pete
    Very good use of chunks that would hit the burn or bury pile for sure!
    I've yet to try it, but the eccentric chuck that I have has a small faceplate that can be mounted on it, I could do something similar to what you have done, but I could have multiple small bowls in one piece, or one larger one, with multiple smaller ones...... I should get onto that eh
    You could do a similar thing with a sacrificial block glued to the base and then drill holes in two or three spots for your worm screw
    Cornwall, England
    392
    Something like this? About 6" long 2" wide American Poplar
    Pete
  1. Waste Not Want Not Finished
    Last Post: 09-12-2013, 03:53 PM
  2. Waste Not Want Not
    Last Post: 08-28-2013, 03:48 AM
  3. waste not, want not....
    Last Post: 05-30-2010, 11:54 PM
  4. Waste not want not.
    By Pete MoncrieffJury in forum Lathe Project Showcase
    Last Post: 03-28-2008, 11:52 PM
  5. Wood waste
    By Drew Watson in forum General Woodworking Q&A
    Last Post: 01-06-2008, 03:20 AM
