Results 1 to 10 of 15
Thread: Hinge Question
    5,533
    Hinge Question
    OK gang, looks like I'll be making a set of doors this weekend, I'm debating between three 'normal' hinges or three strap hinges for the two main shop doors. It is a barn, so the strap hinges will fit in looks wise, but I'm still thinking about the regular ones as an alternative. The main doors are going to be just over 8' tall once everything is said and done, so I'll definitely be going with three sets per door to carry the weight. It'll be good and stout, with 2x4 and 2x6's as the frame, 3/4 ply for the field and I'll dress it up later once I get to the exterior of the shop (ie, later this summer).
    -Ned
    Constantine, MI
    7,891
    I'd go with the strap hinges considering that you're building "stout" doors. I believe them to be stronger overall and the weight of the door will be supported by lags with the stress across the axis of the lag rather than in line with the axis of the screw in a regular hinge. In essence, hinge screws can pull out with a lot of weight on them whereas strap hinges won't let the door sag because of the way they're attached.
    Just my 2 cents.
    www.wrworkshop.com
    Straps. Heavy doors have a lot of tension in them courtesy of gravity.
    5,533
    sounds good to me guys, thanks! Strap Hinges, check! Found some beefy ones at my local hardware store, think I'll go pick them up tomorrow when I get done with work.
    -Ned
    Sep 2007
    Central (upstate) NY
    1,457
    Want me to see if that place in Hamilton that has the big clearance sale going on still has hinges for you?
    5,533
    Quote Originally Posted by Mark Kosmowski View Post
    sure thing, looking for 6 of the largest you can find (strap about 7 or 8" on both halves)
    -Ned
    Sep 2007
    1,457
    I'll look - any interest in half-strap / half-traditional?
    5,533
    Mark, I'm only going to build these once, and at 8' tall, Overkill is just going to be enough, straight strap would be preferable if they have them.
    -Ned
    Sep 2007
    1,457
    Not a problem. I'll buy up to 6 double-strap hinges they have that are big enough. No idea what is left though - I noticed they still had a plethora of hinges, but wasn't too interested in them at the time.
    Sep 2007
    1,457
    Ned:
    I think my phone LCD finally died, but I got you two 8" strap hinges and six 6" ones.
    Up to you if you want the 6" units, but I figured maybe you could put the 8" on top and then three 6" on the doors too, or whatever you feel like doing. They don't have any more 8" units but they still have some 6" ones. I forget the price on the 8" hinges, but the 6" ones were $1.15. I seriously wonder if they are worth more as scrap iron than hinges at that low price.
  1. Hinge Help?
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 11-07-2011, 09:38 PM
  2. Cabinet Door Hinge Question
    Last Post: 04-20-2011, 12:12 PM
  3. Hinge Question
    Last Post: 12-01-2010, 02:11 PM
  4. Hinge question
    By Gene Miller in forum General Woodworking Q&A
    Last Post: 10-04-2007, 12:35 PM
  5. 25 cent hinge mortising jig for any hinge
    By tod evans in forum Jigs and Fixtures
    Last Post: 03-20-2007, 12:10 AM
