Results 1 to 7 of 7
Thread: glue question (stealth mini-gloat)
    Sep 2007
    Central (upstate) NY
    1,457
    I recently picked up a gallon of Elmer's Pro-Bond yellow glue for $7. This is more glue than I am going to use for quite some time. How does this glue compare to other more well-known brands? Also, is there any special way to store this glue if it will be a while before I need to use it?
    Thanks!
    5,533
    stealthy, huh. hmmm. If that's equivalent to tite-bond, it will be similar to what we talked about with that one bottle, remove the skin once it forms and it should keep pretty well, but I'd store it in the basement over the winter, just in case.
    -Ned
    I think if you move it from the large bottle to smaller bottles you will find it keeps longer, and yeah, freezing it is a certain killer!
    5,533
    ayup, you'll want to get a 'working' bottle and keep the big one stocked away.
    -Ned
    Sep 2007
    1,457
    I might repurpose that mostly empty bottle of Tite-Bond molding glue I just used up. Does it need to be thoroughly rinsed first or does yellow glue mix well with yellow glue?
    Austin, Texas
    1,448
    Tite-bond moulding glue has some special fast drying additives, so I would not mix it with the regular Tite-bond/Elmers.
    If it thickens slightly, you can thin it with a tiny amount of water. If it gets gloppy (think winter cold and kleenex - how do you say that nicely?), then it is done. Although I now go through more than a gallon per year, one of my earlier gallons lasted 5-10 years without a problem. Of course, the reason you got it for half price may be because it was already pretty old.
    Charlie Plesums, Austin Texas
    Waterford, MI
    773
    The place where I get groceries has a couple aisles of hardware. In a pinch I've picked ProBond up there more than once since they dont have titebond. Not sure if it has the same exterior rating as TBII or not, but I've never had any glue problems with it and cant really tell the difference from Titebond.
  1. Mini wood gloat
    By Toni Ciuraneta in forum Off Topic Discussion
    Last Post: 09-05-2013, 05:24 PM
  2. Mini Gloat
    Last Post: 01-12-2011, 03:16 AM
  3. Mini Nana Gloat
    By Cynthia White in forum Old Iron
    Last Post: 08-12-2010, 11:41 PM
  4. Crazy weekend and start to the week! Stealth Gloat
    By Bruce Shiverdecker in forum Turning Tool Questions and Show & Tell
    Last Post: 09-12-2008, 12:50 PM
  5. Mini Rig Gloat
    By Pete Jordan in forum Turning Tool Questions and Show & Tell
    Last Post: 04-01-2008, 04:18 PM
