Results 1 to 7 of 7
Thread: Need source for Tee Nuts 1/2 x 13 thread
    Jun 2007
    4,944
    Hi,
    Am I looking for the impossible? I want four Tee Nuts for 1/2 diameter, 13 tpi, bolts?
    This throws the local BORGs, Ace Hardwares, fastener specialty companies for a complete loop.
    If these Tee Nuts are not made, I guess I will have to get some mild 3/8" steel, drill and tap for the 1/2" thread. Then add some small holes for screws to keep the plate from turning.
    I also thought about getting someone to weld 1/2" nuts to thick washers. However, I assumed that this would be pricey (and to think, I used to have welding equipment).
    It is amazing the amount of trouble this "simple" project is causing. As my oldest son would say, "Nothing is ever simple dad."
    Enjoy,
    Jim
    VOTING MEMBER
    30,014
    Hi Jim...try McFeely's:
    http://www.mcfeelys.com/search/t+nut
    Looks like the ones you want are about $1.55 each, in packages of 10.
    Waterford, MI
    773
    http://www.mcmaster.com/
    has 2 different types, Search for "steel tee nuts"
    Indianapolis area
    1,697
    Vaughn and Doug have taken what would have been my suggestions. Good luck!
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    2,784
    But if you only need 4 of them.....I have found them at both the big orange and the big blue. In face one Lowes by me carries knife thread inserts. The Fastenal place in Weatherford looked at me like I was nutz. But they could order them in large quantities.
    Again try the borgs. The 1/2" may be a problem, but I know I've purchased 3/8" from them. They are in the pull out bins by the bolts and nuts. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    N.E. Arkansas
    374
    Check with fastenal to see if they have them.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    Jun 2007
    4,944
    Success
    Hi,
    Thanks to all of you. The problem is solved.
    Thanks again and Enjoy,
    Jim
    VOTING MEMBER
  1. Wing nuts source needed.
    Last Post: 11-08-2014, 04:24 AM
  2. Gun nuts :)
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 07-14-2011, 10:02 AM
  3. my son is nuts
    Last Post: 07-06-2011, 06:57 PM
  4. Could you be as nuts as me?
    Last Post: 02-06-2010, 01:49 PM
  5. T-nuts, or am I nuts?
    By Jim O'Dell in forum Carpentry and Construction
    Last Post: 08-15-2007, 06:43 PM
