Results 1 to 5 of 5
Thread: Bandsaw blades
    Jan 2008
    Austin TX
    405
    Bandsaw blades
    Hello all,
    I recently bought a MM 16 and was wondering where others are getting their blades. I bought a 1" Lenox Woodmaster CT via the internet and just got it home. I'd like to have a couple of different sizes like a 1/2" and maybe even a 1/4" or a 3/8". I'm in Austin TX and would prefer to buy locally but don't know any place that sells the proper length for my saw which is 154".
    Thanks for any assistance.
    Lee Laird
    Austin TX
    Lee,
    I exchanged emails with Mark Duginske. He prefers Olsen bi-metal blades though a lot of folks like Timberwolf. I called Olson direct and because of the odd size of the MM-16, they were able to sell directly to me because it's a special order.
    I'd sure look at Timberwolf too!
    Ken
    Jan 2008
    Austin TX
    405
    Ken,
    Thanks for the info. I'll take a look at each of those. Too bad this size isn't stocked.
    What size blades do you have for your saw? Did you buy the cool blocks and attachment? If so, what is the smallest you'll run with the standard guides before swapping them out?
    Thanks again,
    Lee Laird
    Austin TX
    Lee,
    I bought 154" blades IIRC. That's what the MM-16 owner's manual recommended. I did buy the cool blocks and attachments. I'll probably use it on 1/4" and maybe 3/8". I bought IIRC 3/4", 1/2" 3/8" and 1/4" blades. The saw IIRC, came with 1/2" AND 1". I have the 1/2" that delivered on the saw installed right now. I've only done some test cuts. I'm in the process of finishing my shop. I just finished my 2nd hanging wall cabinet. I've got the moveable shelf to to rip and cut to length. Then paint the two cabinets so I can get my "stuff" off the floor. I'll regain 150 sq. ft. of floor space that way.
    Ken
    11,828
    Timberwolf (actually Suffolk Mfg.) makes all blades to order. There is no problem with 'odd' size requirements.
    Tod likes Ellis blades. Forget why I didn't try them, might have been a minimum order requirement. Dunno, but worth looking.
  1. Bandsaw Blades
    Last Post: 01-07-2014, 04:29 PM
  2. bandsaw blades
    By Dan Diel in forum General Woodworking Q&A
    Last Post: 05-19-2009, 07:20 PM
  3. what bandsaw blades do you use ?
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 11-12-2007, 02:44 AM
  4. sharpening bandsaw blades
    Last Post: 02-15-2007, 04:28 PM
  5. bandsaw blades?
    By Brent Grooms in forum New Tools
    Last Post: 12-12-2006, 06:02 PM
