Results 1 to 7 of 7
Thread: Silver Maple box on presentation stand
    This is my first real attempt to making a box. The hollowed form is made from silver maple. The presentation stand is part of the box and it and the lid are turned from same wood and painted black and varnished. I was a little apprehensive about getting the lid to fit but lucked out and the first time I cut it out it popped right on and fits perfect.Has to be luck because wet wood is hard to fit first time and keep it that way till it is sealed and dried. Second picture is of this hybrid box I call it, with the lid off. Last picture is same box with lid upside down. This is pretty big at 10 " high. Once again multiple coats of varnish to seal the wood and keep from splitting. I like poly but there is a down side to using it, you must use a lot to keep from splitting, but it is too glossy when I take a picture and I don't like this. I tried semi gloss and satin but they come out the same. Mitch
    Attached Thumbnails Attached Thumbnails DSC01856.JPG   DSC01857.JPG   DSC01858.JPG
    Goodland, Kansas
    4,834
    Mitch that is a great looking box. Have you ever tried Minwax Antique Oil or Danish Oil? You can get them from Ace Hardware. I soak green HF's and boxes till they won't take anymore for about 10 minutes then wipe of the excess. Wait 24 hrs and then I give them about 3 more coats after I let each on dry 24 hrs. I haven't had any problems with cracking and doesn't give you the shine like poly but gives it a great natural look.
    Bernie W.
    Bernie
    Thanks Bernie. I knew you used antique oil but I wasn't aware you used it to work as a sealer.We have an Ace hardware close by so I will try it next turning. Your talking about using this oil when turning wet wood aren't you? Wish I had it for that ne bowl I just posted. I think it would of looked great. Thanks Bern. Mitch
    Southeast Pa
    2,019
    I sure like that one.
    Garry
    Garry
    Thank you Garry for the reply. Mitch
    1,289
    Wow, Mitch That is simply beautiful.
    Well done!
    DT
    Don
    Thank you very much Don. Mitch
  1. Maple Aquarium Stand
    By Joe Acquisto in forum Flatwork Project Showcase
    Last Post: 10-20-2012, 05:04 PM
  2. Pet Urn in Spalted Silver Maple
    By Ted Calver in forum Lathe Project Showcase
    Last Post: 07-06-2011, 03:43 PM
  3. One more curly silver maple bowl
    By Nathan Hawkes in forum Lathe Project Showcase
    Last Post: 07-04-2008, 07:21 PM
  4. NE Presentation
    By Mitchell Cholewinski in forum Lathe Project Showcase
    Last Post: 06-10-2008, 02:03 AM
  5. Maple Bowl and stand
    By Randy Privett in forum Lathe Project Showcase
    Last Post: 10-14-2007, 08:40 PM
