Results 1 to 10 of 11
Thread: Green wood
    Green wood
    I am new to woodturning and have read that you should turn green wood then let it dry for 1-3 months and then finish turning it. I was wondering how far do you go turning the first time and is there any way to help prevent cracking on a piece that has been turned over the entire surface and there is no bark left?
    Remlik, Virginia
    88
    Quote Originally Posted by curtis tolbert View Post
    For rough turning the general rule of thumb is 1" for every 10" in diameter. I have used this gauge with good results with most wood. I Anchor Seal the end grain, the rim and then wrap in a paper bag and forget about it for about a year. There is no way it would air dry in several months in my shop. Of course you could just turn the green wood to finished thickness
    The environment in which the roughed out bowl will be kept has a lot to do with the success. In shops like mine in Eastern VA with no climate control I have a very high success rate. In drier areas and controlled environments it is a little more uncertain as often the relative humidity is lower.
    There are many other options including denatured alcohol drying, boiling, covering with shavings, plastic bag drying, microwave drying and I even heard of one guy who uses cardboard boxes. also you could build a kiln.
    The best approach is to do a number of searches.
    Barbara
    Goodland, Kansas
    4,834
    I agree with Barbara. The one thing I think you will find is if you don't use like the DNA (denatured alcohol soak) it is going to be longer that 1 to 3 months. I have did several like that before I started the DNA soak and it is like 12 to 18 months depending on thickness. With the DNA soak it is like 2 to 3 weeks.
    Bernie W.
    Thanks for the info. Where can I get more info on the dna soak? I searched this site and could not find anything?
    Curtis, Dave Smith did a lot of testing and put his results in this article.
    http://www.woodcentral.com/cgi-bin/r...cles_473.shtml
    A lot of people follow his methods (or some variant of it) and get good results.
    Thanks Vaughn. Thats a lot of good information! Yesterday I turned a vase (outside only) out if oak. It is about 12" high and 4" thick at top and bottom. I brought it into the house and this morning it had already cracked in several places.
    Does anyone know if isopropyl alcohol will suffice? I have several bottles already.
    Drums, PA
    292
    Most isopropyl contains 30% water, most DNA is in the mid 90%. It's likely the alcohol you have has too much water.
    Now if you have some moonshine hanging around, that might work.
    Quote Originally Posted by Ron Sardo View Post
    Yeah, right off the still, uncut, it would work, but man, what a waste of moonshine
    If I had moonshine it would probably go straight to my gas tank!
  1. Question for those who turn green wood
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 02-12-2013, 03:51 AM
  2. My first green wood bowl
    By Rob Keeble in forum Turning Tool Questions and Show & Tell
    Last Post: 07-27-2009, 11:42 AM
  3. Scored some green wood. now what.
    By Joe Penney in forum General Woodturning Q&A
    Last Post: 02-21-2009, 04:58 PM
  4. Green wood bowl
    By Shawn Lakes in forum Lathe Project Showcase
    Last Post: 06-03-2007, 03:16 PM
  5. What *exactly* counts as green wood turning?
    By Bill Lantry in forum General Woodturning Q&A
    Last Post: 05-26-2007, 07:55 PM
