Results 1 to 6 of 6
Thread: A Third Hand
    A Third Hand
    You know, when you are putting together a cabinet, and you get the glue going and the pieces all together, and something goes "Boink" and you now have cabinet parts and glue all over the place
    I was building this little cabinet for the L shop, we just got a new BIG color laser printer and we needed to put it in a space with an existing dot matrix printer that we use for printing the invoices. Not fine woodworking, but a quick and utilitarian piece of work.
    I dadoed the sides in the cabinet, and the back panel as well, so while I had the dado blade in the tablesaw, I made up a few assembly blocks........
ID:	21481 Click image for larger version.
    This is also a good way to use up scraps from the cabinet.
    Just cut the dados and then use these blocks to hold things in place.
    A dry fit
    getting ready to glue up....
    Here it is all glued and stapled together, and I even put the shelves in for the picture.
    Like I said, not fine woodworking, but it solves a space problem, the Dot Matrix printer will go on the top of this cabinet, and the new printer will go to the side of the cabinet.
    The assembly blocks sure make this kind of assembly easy!
    Constantine, MI
    7,891
    Neat idea. I need to remember this next time I have the dado in place!
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Tokiwadai, Japan
    2,882
    Nice, Stu....
    I also see your fence clamps in place. I need to get a couple of those.
    Fort Washington, PA
    180
    Great idea Stu... anything to make something quicker but at the same time more accurate without a whole lot of fussing I'm all for.
    Build it Break it Fix it ...repeat
    Honolulu, Hawaii
    1,103
    A Third Hand
    Stuart,
    Great idea. I'll use it too, if you don't mind.
    Keep those good ideas coming. You got a bunch of 'em. Must be something about the Canadian blood mixed with the Japanese air. Very creative.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Thanks gents!
    Not an original idea at all, I got it along the way from someone else, wish I could remember who, to give them credit, but I cannot
    Greg, them clamps on the TS fence do work great
  1. Like A Magic 3rd Hand!!
    Last Post: 07-02-2010, 02:53 PM
  2. Hand saw
    Last Post: 08-02-2009, 02:59 PM
  3. looking to buy my first hand plane...
    By Mike Gager in forum Neander Woodworking Q&A
    Last Post: 04-10-2008, 11:59 PM
  4. To hand cut or just jig it?
    By John Daugherty in forum Neander Woodworking Q&A
    Last Post: 03-14-2008, 06:25 PM
  5. Hand screws
    By Wes Bischel in forum Hot Deals
    Last Post: 02-09-2008, 02:47 AM
