Results 1 to 10 of 10
Thread: Chamfer using Router Table or Table Saw
    WNY, Buffalo Area
    873
    Before I do it, I thought I would throw this out for some feedback.
    I am in the process of making 3 raised panel doors for a cabinet. I am planning on putting a 45 deg. chamfer on the outer edges of the doors.
    Would it make a difference if I used the table saw or router table to put this chamfer on?
    I don't think it would, but I know there are alot more people out there with alot more experience than me.
    Thanks !
    www.tinyurl.com/thewoodshoppe
    11,833
    Don't know about the experience part. But I avoid using the table saw whenever possible. Call it a coward thing. I would use the router. Even if it weren't for the fear factor, I don't have a table big enough to properly run a door through my TS blade. Router all the way.
    I've not done a lot of chamfers, but I've had better success using my table saw. For me, there's less chance of burning the wood, and with the right blade, my TS can cut very smoothly, so little or no sanding would be necessary.
    Southern Louisiana
    947
    sean, they both have their advantages. I would probably go straight to the router because my table saw is going to leave saw marks. maybe if you have a really expensive blade and it just got sharpened it wouldn't, but that usually isn't the case for me. To avoid burning it as vaughn mentioned, make the bulk of the cut first, then do a final pass taking off just a little.
    just my thoughts. good luck
    Chris
    Inside the Beltway
    2,666
    Sean,
    What's easier to set up for exactly the right cut? My vote would be router table, since its easy and repeatable and you're not taking off much wood...
    Of course, it depends on what you have. Nice big flat router table? My biggest worry would be keeping the piece dead flat...
    Bill
    9,077
    I do a lot of chamfers. My favorite way is a Colt and Pat Warner's offset base. The small footprint really follows the edge. If your material or your table/fence aren't perfect, the large surface will reference poorly off the material. As Bill said "Nice big flat router table? My biggest worry would be keeping the piece dead flat..." The small footprint on a router follows better for me.
    Rochester
    846
    I've got a large diameter 45 Infinity chamfer that leaves fewer machine marks than the TS and does a terrific job, but otherwise I'd pick the TS over a small chamfer bit just to ensure consistency
    Got Wood?
    be carefull if you go with the router.....tearout exiting the cut can cause problems.
    WNY, Buffalo Area
    873
    Thanks for the advise everyone!
    I think I am going to be going the table saw route. My blade is fairly sharp(LU83R 50 tooth), the pine is pretty soft, and I am concerned about tear-out from the router bit. Also in the process of making the chamfer, I will be cutting both with-the-grain and across-the-grain (on the ends of the rails). I think that the saw blade would probably handle this type of cut a little better.
    WNY, Buffalo Area
    873
    Quote Originally Posted by John Downey View Post
    Just for variety's sake.....
    A sharp block plane!
    John,
    If I was what I would consider to be proficient with a block plane, I might consider it. However my abilities with a plane are nothing like where they probably should be.....so it will be a power tool for the job.
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Router Table Router and Lift
    Last Post: 10-08-2008, 06:21 AM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Table Saw. Band Saw. Router Table. *** ALL SOLD ***
    By Rob Bodenschatz in forum Old Ads
    Last Post: 05-31-2007, 04:56 PM
