Results 1 to 4 of 4
Thread: Quick project... sandpaper box...
    499
    I am finally putting the finish on the Table that I have been working on forever, but that is a different story. Here's the link to that album.. Go the the last 10 or so pictures.
    So I am finishing this table using Waterlox, and a hand rubbing technique that uses wet/dry sandpaper to rub in each coat. So of course I needed wet/dry sand paper. Off to Peachtree Woodworking to purchase bunches of wet/dry sand paper. 220/320/400/600/800/ and I really need some 1000. I got a box (100) of each. I like having supplies at on hand.
    Now my sandpaper pile is really starting to bug me. So I was looking at the Projects Pages over on www.lumberjocks.com and saw several sandpaper organizers come by.
    So here is my contribution to Sandpaper boxes...
    I cut the back stops for each slider on the bandsaw.
    I made each of the sliders out of left over flooring. The man-made stuff that snaps together. I put glue on the joints and ended up with perfect slider's.
    The sides are 3/4" oak ply and the top, bottom and back are 1/2".
    So here are the other views of the project.
ID:	21847 Click image for larger version.
ID:	21846 Click image for larger version.
ID:	21842 Click image for larger version.
    And I had planned for it to go back on the same shelf. So the 14 7/8" height worked like it was planned.
    I had been messing with the parts over the last few weekends. It took about 2 hours to cut all of the dados and do the final assembly.
    The design just evolved starting with the size of a piece of sandpaper and the size of the sliders.
    As always there is a web album with notes.
    30,015
    Very nice, Bartee. Ive got a similar, but simpler sandpaper case that was from an old retail display. I could really use a good solution for storing the 2" sanding disks I use on the lathe.
    I love how some things can add to your woodworking enjoyment. Well done Bartee.
    Grew up here in south Ms...the "Pinebelt"
    42
    Nice
    Very nice. One of those things I keep saying I'm going to do but just haven't. Well just maybe yours will be the inspiration I needed.
    "Humility is a strange thing, once you think you have it, you have lost it"
  1. A fun and quick little project. A kid's chair.
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 10-24-2014, 10:29 AM
  2. Toy cars, quick project
    By Jeff Horton in forum Flatwork Project Showcase
    Last Post: 10-29-2011, 03:08 PM
  3. Quick project
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 04-30-2008, 05:55 AM
  4. Quick Shop Project - Sanding Cart
    By John Hedges in forum Flatwork Project Showcase
    Last Post: 04-26-2008, 02:01 AM
  5. Quick weekend project
    By Matt Dunlap in forum Flatwork Project Showcase
    Last Post: 01-15-2007, 06:18 AM
