allen levine
- new york city burbs
If I build a simple box, approx 18 x24,30 inches total height put it on casters, do I need to add 2x4s as a frame, or would 3/4 plywood screwed and glued be sufficient to support the press without the top bellying in or being wobbly?
I intend on mounting the castors on 2x4s, then attaching that to bottom piece of ply, and double sheet(2 pieces of 3/4 inch plywood) top surface supporting the press.
Assuming you will laminate the two top sheets into a single 1 1/2" thick top you should not experience any sag without additional framing. Never-the-less, the oak trim would still be a nice touch
I guess my question would be "Box, why do you have a 75 pound drill press on you?"
I've had about 3 hours worth since Monday morning.
