Gari Biasillo
- Vancouver
I've had a built-in storage project on my 'to do' list for over a year but had never had the time to do it. Until now, that is. My wife and 2 1/2 yr old son are visiting Japan for two months, visiting relatives and friends, and generally having fun, while I'm stuck here working and paying the bills
Disclaimer: I haven't done any serious flat work for years (I fell into the bottomless pit of lathe-land!), so you'll see lots of errors, and imperfect work!
Here's the alcove that needs the storage. Usually a dresser of some sort would got here but I'm going for something different.
I've built the carcasses for the two main storage cabinets. The first is tall, which will house the vacuum cleaner, and has a little cubby hole at the top. I'll put some ply later: maybe some painted peg board? The left panel is Walnut ply, already finished with shellac and WOP.
To the left, is the main cabinet. Three draws will go in the bottom, two sliding doors in the center, and two sets of two sliding doors at the top. The top is Walnut, and the inside shelving is Mahogany, which saves a bit of $$$ and the contrast should look nice IMO.
It was a tight squeeze but it fits! Oops! I dinged the wall!
I used plugs to fill the screw holes, which is a first for me. The top bungs will end up being hidden (more on that later) but the inside ones will be visible: the contrasting Walnut/Mahogany should look nice when the finish is applied.
I plan on putting a plywood back on the main cabinet but I'm not sure what to do about the socket on the wall, so I'm looking for some advice...
Should I just cover it up, cut a whole in the back so I can access it if need be, or something else?
Next up - the face frames. I'll post a follow up when that part of the project is complete.
Thanks for looking!
-Gari
Thanks for looking!
-Gari
