James Brown
What is the best way to clean built up wood tar or resin from router bits. I just came across some that are pretty caked up and have been that way for some time. Thanks much, Jim.
...There is no way it can attack enough surface area of the thin layer of silver solder in between the carbide tip and the cutter blank it`s welded to.
...I use it all the time and never once lost a carbide tip ....
