Alan DuBoff
Former Member (by the member's request)
I was reading on OWWM recentley and saw one of the members referred to the Yates-American G-89 as the "Baby" of the commercial class saws of yesteryear...
So, it seems only fitting that my G-89 got a makeover with a Biesmeyer fence system, in no less than puni-grey, the official Delta puni color. I believe I am officially a part of the puni family now Jeff, and I might add that the colors go well with my table saw, I'm not unhappy with them at all. This is a nice fence.
So, I wasn't as lucky as Michael, although he had to change a couple things, after I pulled the stock fence and rail from the saw, I got it setup, and uh-oh, the miter slots are too wide by a tad, so off to the grinder I go. I got that fixed, and got it fitting, and naturally no holes lined up...
Looking at my table, I saw I could comfortably put in 3 holes, between the webbing, and I think that should hold it well enough. So, I got my trusty 3/16" bit out, drilled the 3 holes, and then tap'd them to 1/4" - 20, so the fence screws would go right into the cast iron table. Then I put a bolt, lock washer, and washer on the backside of the bolt, securing it to the backside of the front wall of the table, if that makes sense.
I didn't use the rear rail, but might add it on as I'm thinking about adding a small router table possibly in the right side, where I have about 6" aprox of rail extended past the end of the table.
(linky pic)
(linky pic)
I think you are Really going to enjoy that fence. How long did the "Fence" (not the rails) turn out to be, and did it just have the little pad (like mine) under the fence to ride on the table, (no foot)?
