Family Woodworking
Go Back   Family Woodworking > General Woodworking Area > General Woodworking Q&A
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
General Woodworking Q&A Ask your woodworking questions here - get the answers, too!
Reply
Thread Tools Display Modes
  #1
Old 02-10-2007, 07:58 PM
Garrett French Garrett French is offline
Question Most Dangerous Power Tool?
What's the most dangerous power tool?
My answer would be: "whichever power tool you're using!"
But then... I'm not a woodworker
Which power tool/s, in your experience, are the most dangerous?
__________________
I'm the editor of ToolCrib.com.
Reply With Quote Share on facebook
  #2
Old 02-10-2007, 08:00 PM
Don Taylor Don Taylor is offline
Former Member (by the member's request)
For me that would have to be the chain saw. I've never felt comfortable with one.
Don
  #3
Old 02-10-2007, 08:09 PM
Ian Gillis's Avatar
Ian Gillis Ian Gillis is offline
Lots of possible answers here. I think I'd have to go with "the machine that's most poorly maintained". Fences out of alignment, hold downs that don't hold, shut offs that don't always work on the first try.
It's okay to have a television that needs a smart tap to get it working properly, but it's not acceptable with powerful shop machines.
__________________
All the best,
Ian G
**Now holding auditions for a catchy new signature**
  #4
Old 02-10-2007, 08:21 PM
Jeff Horton's Avatar
Jeff Horton Jeff Horton is offline
The tool you are least knowledgeable of or most careless with.
Jeff
__________________
God grant me the senility to forget the people I never liked anyway, the good fortune to run into the ones I do, and the eyesight to tell the difference.
Custom built boats and Kits
  #5
Old 02-10-2007, 08:28 PM
yeah - I'm wary of chainsaws too... I've used my share of bow saws to cut up brush and cut myself pretty good doing that
Ian - I wasn't aware of the relationship between safety and tool maintenance...
But let's say you've got a shop full of well maintained tools?
Are there any tools that are just plain more dangerous than others?
Also Ian do you think a more useful/interesting line of discussion be - what are the most important points to check on powerful shop machines to insure safety?
__________________
  #6
Old 02-10-2007, 08:32 PM
Steve Clardy Steve Clardy is offline
Guess I give my 3hp powermatic shaper more respect than any machine in the shop
__________________
:lurk:
  #7
Old 02-10-2007, 09:14 PM
Ian Abraham's Avatar
Ian Abraham Ian Abraham is offline
The operator
But seriuosly, you want to ensure that whatever guards and safety features it has are actually there and working, and that nothings likely to come loose and break while you are working. Like you dont want to use a router with a dodgy collet or a saw blade with a stess crack in it
But nine times out of ten it comes down to the operator making a mistake.
I also vote for chainsaw as the most dangerous, but at least it's obviously dangerous. Big noisey machine with exposed fast moving cutters, there is no mistaking it could do some damage if you operate it carelessly. There aren't many other common machines where you should wear as much safety gear as a chainsaw.
Cheers
Ian
  #8
Old 02-10-2007, 09:19 PM
Art Mulder's Avatar
Art Mulder Art Mulder is offline
#1 - A tablesaw that does not have a splitter, and/or the fence is not parallel to the blade.
#2 - Circular saw. I go out of my way to avoid using a circ saw. I usually use a jig saw if/when I need to break up a large sheet of plywood. Slow, yes, but I'm just much more comfortable with it.
  #9
Old 02-10-2007, 09:34 PM
Frank Fusco's Avatar
Frank Fusco Frank Fusco is offline
Send a message via Skype™ to Frank Fusco
The question was rather broad, "power tool". My tractor is a power tool as is my truck, etc.
But, to limit the response to a wood working shop, I'll repeat what my son, an emergency room physician, says.
The most frequent serious injuries are with table saws.
The second most frequent serious injuries, in terms of numbers of incidents, are from miter and/or compound miter sliders.
However, in terms of most devasting the CSM is far and away the worst. Those usually involve finger amputations. The table saw accidents are serious gashes but (usually) leave the fingers in place.
He also says that most of those injuries are to guys like me, middle age to retired age. And, they all say the same thing, "I never do it that way, but just this once........".
  #10
Old 02-10-2007, 09:37 PM
Frank Pellow's Avatar
Frank Pellow Frank Pellow is offline
The most dangerous woodworking tool that I actually use is a chainsaw. There are others (such as a radial arm saw used for ripping) that I will not use.
__________________
Cheers, Frank
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
