Mark Kosmowski
- Central (upstate) NY
Well, back in May
my wife and I replaced the carpeting in the bedroom hallway with laminate flooring. The place we got the flooring from didn't have the right color transition pieces and due to a spatial transposition reality - brain disconnect (a goof) one of the transition pieces needs to be a bit wider than the commercially available bits are.
Last night, Ned stopped by to play with the lathe and I spent the evening fiddling with the router table finding the right height and fence stop to get the elliptically rounded over profile I wanted from a friend's bit (part of a Holbren raised panel set - I had to fiddle to get only the 1/3 of the profile that I wanted).
Among other things, I either learned or relearned that if I lock the router (a PC8529) in the "freely plunge" setting and use the above table adjustment know dealie that it is much easier to find a consistent height rather than monkeying around with trying to plunge the router up to a fixed height and locking it down with the plunge lock control.
At any event, I now have the router setup to give the profile I want.
My goal for the weekend is to have, at a minimum, the transition pieces all ready for finishing. I'll check back later and post pics to let you all know if I've met my goal.
