| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| New Tools Questions, evaluations, and Show & Tell for modern-day woodworking tools. |
Thread Tools | Display Modes |
#11
There are quite a few options when it comes to router bits indeed. I own a set of the Lee Valley and am quite happy with them.
On the other hand , if I could do the purchase over , I'd get the set that Pat Warner , the "RouterMan" uses and recommends. You can read about them here... http://patwarner.com/starter_bits.html Elliott |
#12
For heavy use bits I buy Whiteside, Eagle America and Freud. For the "cheap" or one project bits I buy PriceCutter, Woodcraft and Rockler bits. Some the bits at the box stores are OK but it seems they are priced closer to the premium bits without the same quality.
#13
#14
hi doug
i use a few diffrent brands right now and i like them all so far. i am not an all day everyday user, so my original set is still going strong. they are hickory brand from the borg. i have a few rockler bits that have been fine also. just recently i scored the deal of the century on 33 amana bits (about $3.00 each) so this is what it looks like now...
__________________
what are you building today ?? GRIZZLY |
#15
Sharpening bits
I use a lot of plunge bits from Magnate http://www.magnate.net/ These types of bits are easy to re-sharpen yourself. If there is a bearing on the bit it can be removed and sharpened as well using the duo fold diamond wet stone http://legacywoodworking.com/products.cfm?product=22 I touch up all the bits I am useing to eliminate burning and reduce sanding. If you are willing to sharpen them yourself, the cheaper ones will work longer for you.
Mike
__________________
Make your "go-arounds" worth waiting for! |
#16
After experimenting with about 5 different brands, I settled upon the bits from Lee Valley and they now make up about 95% of the bits that I own. I can certainlt recommend them.
Also, I see that they are the third highest rated brand in the test refered to by Jim Bergstrom in post #4 in this thread. I have not tried the brands rated 1 and 2.
__________________
Cheers, Frank Last edited by Frank Pellow; 10-28-2007 at 03:50 AM. Reason: spelling |
#17
doug, here`s a coupla pics of one of the disposa-bits that i run, this one finally got a small chip in one flute after cutting 20-25 radiuses. the cuts where made in a single pass in 3/4" mdf....the bit still cuts fine.
__________________
associated with several importers and manufacturers. |
#18
Most of my bits came from the close-out/scratch and dent room of....here I go again....Grizzly.
It was a discounted, already inexpensive, set that came to about $1.00 each. After buying them, I read one of those reports and learned mine should tear rough edges. Well, they did a little. But now, before using one for the first time, I smooth the flat to the cutting edge first with a diamond stone. They cut just fine and smooth. For specialty bits, I have had good luck with MLCS. They now carry some four-wing bits that are really nice and catch-free (that doesn't mean you can get careless).
__________________
"Hello sunset farewell world. My ship has lost sight of shore and rides upon the waves of Nevermore." Brent Stephen Fusco 1969-1996 |
#19
Quote:
Quadra-Cut Bits:
#20
charles,
chip load is a science unto itself and it`s really the one relevent factor that affects all cutters whether it`s a routerbit, shaper cutter or drill bit.... how about expanding on the subject? thanks! tod
__________________
| Thread Tools | |
| Display Modes | |
