- ABQ NM
I'm considering retiring my tired two-year-old B&D belt sander. (Don't laugh, it's paid for itself several times over.) It still runs, but the squeal and squawk from the bearings is about to drive me nuts. (It's screetched and hollered since the first time I used it, but no matter how hard I've tried, I can't kill it.) Also, the dust collection is worthless, and I want something better.
I use my belt sander quite a bit, since it's a relatively fast way to flatten a cutting board glue-up, and I'm still making cutting boards on a fairly regular basis. Even if I use the planer or router bridge to do the majority of the flattening, I generally start with the belt sander to knock off the high spots.
I've been looking at the 3" x 21" Porter-Cable with the variable speed. I'd like to stay with the 3x21 format since I already have a fair number of belts on hand, and the cost difference between the 3x21 belts and the 4x24 belts seems prohibitive for my needs. Also, my projects are comparatively small, so the smaller size seems it'd be easier to handle. I realize dust collection with any belt sander is iffy, but I'd plan to attach a shop vac hose to reduce the dust as much as possible.
Do any of you folks have any experience with this sander, or have any recommendations for a different one?
TIA -
TIA -
here in public. You've made my month!
