Family Woodworking
Go Back   Family Woodworking > General Woodworking Area > General Woodworking Q&A
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
General Woodworking Q&A Ask your woodworking questions here - get the answers, too!
View Poll Results: whats your go to glue?
tite bond 1 the original 13 22.41%
tite bond 2 exterior use? 24 41.38%
tite bond 3 longer open time and shelf life 20 34.48%
other 9 15.52%
Multiple Choice Poll. Voters: 58. You may not vote on this poll
Reply
Thread Tools Display Modes
  #1
Old 06-07-2008, 11:11 PM
larry merlau's Avatar
larry merlau larry merlau is online now
Moderator Team
Send a message via Skype™ to larry merlau
What type of glue? and why?
what type of glue is reccommended by you for your work and why? i will simplfy this to just the tite bonds not the cna or gorrilla types just your go to glue for anything,, cabinets, furniture glue up, panels the time ranges arent to differnt from what little i know..
type 1=20 mins
type 2=20 mins plus exterior applications
type 3=30 mins longer shelf life
__________________
one hand washes the other
Reply With Quote Share on facebook
  #2
Old 06-07-2008, 11:18 PM
Moderator Team
help someone
delete the other one without the poll. thanks tried but couldnt find the switch
__________________
  #3
Old 06-08-2008, 12:15 AM
Ron Sardo's Avatar
Ron Sardo Ron Sardo is offline
I'm going to answer this as if I was doing segmented turning.
Titebond 1 because it's the strongest of the three.
If I need a longer open time, I use white glue (as in Elmer's)
__________________
www.simplyturning.com
  #4
Old 06-08-2008, 12:17 AM
Moderator Team
And what a fool???? i am
please put this in the general forum guys i was day dreaming i quess i dont know how it got here i dont do spinny just look and listen to you folks
__________________
  #5
Old 06-08-2008, 12:33 AM
Ken Fitzgerald Ken Fitzgerald is offline
Larry,
I use the original Titebond. In fact, I just bought another bottle this week because I'm about out and I'm building cabinets. Yeah, I have less working time but I've had such good luck with it....why try anything else.
  #6
Old 06-08-2008, 01:17 AM
Tony Baideme's Avatar
Tony Baideme Tony Baideme is offline
I use Titebond II for most projects and either Elmer's (both white and yellow) or Gorrilla for others. I don't do all that much glue-ups yet and I'm still learning.
Aloha, Tony
__________________
"Time flies like..... an arrow,,,Fruit flies like..... a banana."
Ah,,,to live in Paradise!
  #7
Old 06-08-2008, 01:23 AM
Art Mulder's Avatar
Art Mulder Art Mulder is offline
For the past few years I have generally used the 2002GF from Lee Valley.
I also picked up some Titebond2 last fall, and have started using that more often.
I don't glue enough -- hobbiest! -- to have that many bottles on the go. In fact I usually write the date on the bottle in marker when I buy it so I can judge how old it gets -- usually goes 12-16months before I'm done.
__________________
  #8
Old 06-08-2008, 02:19 AM
Vaughn McMillan's Avatar
Vaughn McMillan Vaughn McMillan is online now
Administration Team
Quote:
Got 'er done, Larry.
Of the yellow glues, I use Titebond II. I was buying it by the gallon when I was making a lot of cutting boards, but I've not done a lot of flat work for a while, so the last gallon has lasted me well over a year. (With a lot still in the bottle.)
For most of my work these days, CA and epoxy are my go-to glues.
__________________
  #9
Old 06-08-2008, 04:04 AM
Ed Nelson's Avatar
Ed Nelson Ed Nelson is offline
TB2 has worked well for me! No real reason why. It's what I've used for a while and I'm happy with it! If I start doing more veneers I may look more into the ureas.
  #10
Old 06-08-2008, 04:05 AM
Stuart Ablett's Avatar
Stuart Ablett Stuart Ablett is offline
I don't use Titebond, because it is about 3 or 4 times as expensive as the Japanese brand
The glue I use would be your typical PVA glue, which would be a Titebond #1 or #2 if it is for outside.
Why? Works good, is cheap and has not failed me yet!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
