- Thomasville, GA
I've had a couple of printing projects that I needed to help along by pausing the print while I did something else. A bit of research led me to an Octoprint add-in called Multi Colors. The intent of the add-in is to pause the machine, keep the motors active to eliminate movement, and allow the operator to change the filament color. I had the perfect subject for that operation with the panel for my laser setup. I printed the first panel in all blue but, of course, it was difficult to see the lettering. So, I tried the add-in and it worked quite well. In the case of my panel, the top three layers are the lettering, so I set the routine to stop after the fourth layer from the top. It worked out pretty well, but I need to do a bit more clean up amongst the letters.
Another way I used the add-in is on some pop-top openers I printed based on a plan on Thingiverse. I'll detail the openers in a different post. The original had a slot on the flat side into which one can insert a 10mm by 1mm rare earth magnet. I made a few that way, then changed it a bit to pause the print while I drop in a magnet. As you can see, that works well also.
If you haven't already found it and are interested, here's a link to the web page.
