- Springfield, Missouri
And a learning experience too.It's gonna be a sweet machine!
The spindle is coming with a full set of E20 metic collets, but I've got a full set of imperial E20 collets, with a 1/2" size already.Just make sure you can hold a 1/2 shank cutter - that is REALLY important.
Today I was at my clients shop helping him to optimize a program for a 3D whale that he sells. I had his machine cutting at over 400 IPM.
Darren what are the dimensions of your panel, I am working on my layout also. I am planing on segregating the AC wiring and power from the signal. In my case it may be more of a problem because I am planning on using the external CNC control as opposed to the breakout board...The white board will probably be some aluminum clad plywood I have on hand. The front and rear mounting racks on the cabinet above can be moved forward or reverse. I'll probably move the rear set forward and mount the plywood to it so that I can do some wire-routing from the back side to keep things clean and balance the weight in the cabinet as it may go on casters.
The bottom 4 power supplies will be for the drivers, they are 70v each. I will share one of the two Y axis drivers with the A axis as both won't be moving the motors at the same time. The top one is a 24v Power supply for the board, I may also need a 5v power supply in there as well. I plan to run 220v to the cabinet, through the DIN breaker, and then distribute that to the power supplies and VFD.
That one is 19" wide, 24" tall. Though for the cabinet above, I could go to about 30" tall.Darren what are the dimensions of you panel, I am working on my layout also. I am planing on segregating the AC wiring and power from the signal. In may case it may be more of a problem because I am planning on using the external CNC control as opposed to the breakout board...
Yeah, and it comparison to an electrical cabinet that was big enough, this is cheap. I'll add some casters and have a nice workstation to use by the cnc.Thats going to make a nice cabinet.
The motor spacer was 100%, also the little power supply mounts. I'm only using 20% on these motor covers. They aren't really structural, or at least not supporting anything, plenty strong for their purpose.What kind of infill do you use for something structural like that?
