The rest of the parts came today, so started mounting them to the board.
I picked up a L14-30 receptacle to mount on the cabinet. I'll be using a 30 amp generator cable to connect power from the new wall circuit.
The power will come to the main breaker at the bottom right of the board and then over to the contactor switch to the left of it, power from it will go to the red and black DIN terminals to the left of it.
The contactor switch will be engergized from a on/off paddle switch, which will be the main switch for all things powered in the enclosure.
The DIN Terminals are connected with bars that I've removed every other pin from to connect all the black terminals, and same for the red. The beige colored ones will be a buss for the neutral (for 110v), and green connects to the ground, which contact the DIN rail itself, which is touching the aluminum on the board (the main ground plane). There will be a ground terminal and ground wires also ran to the various components too.
Power from the red/black terminals will go up to breakers for the power supplies, VFD, and power for the pc/monitor.
Anyway, here's the progress so far, the board is screwed to my office wall to work on it. I need to pickup some more screws to mount the rest of the drivers, power filter, and the controller boards.
