Stuart Ablett
- Tokyo Japan
Nothing quite as nice or involved as John's router sled, I made this to flatten the top of my Roubo bench and to do some slabs too.
I really like the look of John's DC mount, I might add that kind of thing to mine.
I made two side pieces that can adjust up and down so I can do the benchtop and then do slabs later.
The adjustable sides are attached by bolts into threaded inserts on the sides of the bench.
You can't see it really in the pic but I checked for level across the bench in four positions then diagonally as far as my 3'level would reach.
Finally I got out my string I use on construction sites and did an "X" pattern across the whole thing and the strings just touched.
I do not know, without a much longer level how I'd check for the two sideboard runners to be parallel and level with each other, any suggestions?
I knew this one corner was a bit high, so I started there.
As I did more passes I was getting almost complete width cuts, my straight edge says it flat.
I put a light along the edge (this just shows that the light is on and bright)
I cannot see any light, so it looks flat.
I'm using the dish carving bit, it's the only thing I have, it works OK but I have ordered a slab bit...
This one which I hope comes soon.
Some of you might remember my slabs of wood up on my rooftop, many of them are rotting.
I need to do something with them so I'm finally getting some off the roof, I hope to make some tables and some other things with them, but first I have to make them flat
Cheers
Stu
Cheers
Stu
