Stuart Ablett
- Tokyo Japan
I remembered that I have this straight bit that has a top bearing on it, but j can use it to do some slabbing for now.
It us 28.5mm or 1-1/8" diameter.
With this bit and the 3-1/2 hp router I can easily take a 1/4" deep cuts... :O
Amazing!
I modified the vacuum hose attachment to fit on this router, but really it's nearly useless. Instead I'm thinking of some kind of retractable cover, like maybe an old roll screen that could be attached to the router sled and just pull out and retract as the sled us moved back and forth making the space between the runner on the sides of the bench top and the ends of the bench into a big box that the DC is hooked up to, if that makes sense.
Sent from my SCV43-u using Tapatalk
Amazing!
