- The Gorge Area, Oregon
Perhaps we're over complicating this with details. A simpler rule of thumb would be that if the motive force is X and moves distance Y you can't lift anything heavier than X more than distance Y. You can move things heavier but that reduces distance and you can move things further but that reduces the supported weight. So for a 50lb actuator that moves 24" the most it can move is 50lbs for 24".
The reason the screw works so well is that you're moving a longer distance for a given input force.
Note that that isn't taking into account any system losses, which will vary wildly depending on the build.
