3M Scotch-Brite Hand Pads for Woodworkers
Scotch Brite 6" x 9" flexible abrasive pads do a great job of smoothing finishes between coats and rubbing out final coats. The pads are much more durable than steel wool; they don't shed fragments, leave no oils behind (they're perfect for use with water-based finishes), and they can be washed and re-used as often as needed.
Pad Grades
Extra Coarse pads are very aggressive - similar to #4 steel wool. Use them for removing finishes, smoothing edges or removing heavy rust on steel or iron.
Coarse pads are fairly aggressive, and will cut finishes well enough to eliminate minor surface texture.
Medium pads are about equivalent to 0 or 00 steel wool, leaving a low satin sheen.
Fine pads are similar to 4/0 steel wool, polishing to a beautiful satin lustre.
For the smoothest job on flat surfaces, use a
Hand Pad Holder. Pads can be attached or removed instantly, with no hardware to mar your finish.
I have used the grey (Medium) and the Maroon (Course) ones
