glenn bradley
- SoCal
I didn't think we needed another thread from me about urns so I will just tag these on here. Similar construction to the one above; dovetails this time.
The top is a floating panel. The scribble on the piece of paper is the targeted profile.
The joinery goes like so.
And it ends up like so. Here I have it taped off as part of the finishing process.
The bottoms are fitted as in the first one posted above. I cut the small rabbets with a FTG blade.
You can see that I pre-finish the top edges of the boxes prior to assembly. I also pre-finish the panels. This prevents any peel-a-boo appearances of unfinished areas during wood movement.
This one is black walnut and curly white oak.
This one is black walnut and pecan.
This is just the initial top coat. I'll add a pic once they are truly done with feet and all that.
