Anyone have experience with Natura OneCoat?
No experience with it.
Seems to be a two-part mix, like epoxy oar polyester resins/hardeners. Makes me wonder about touch-ups or repairs.
$42 for about 12 ounces seems a bit pricey, but worth it if it performs as advertised.
I have not used Natura OneCoat. From what I read it is another of the new hard wax oil finishes.
I had never heard of such a finish until one of the members of my woodworking club who is a professional cabinet maker and quite talented told us about a new finish he had used to finish a courtroom he had been commissioned to do. He built the judge's bench, the witness box, the clerk of court desks, the bailiff's desk, the bar, the tables for the attorneys and prosecutors, the jury box etc. etc. etc. He even constructed the paneling which was used to finish the walls behind the judge's bench, and the other areas of the room. He also built the doors to the judge's chambers and jury room. It took him more than a year. It was designed by an architect and the architect specified a hard oil wax finish made by Osmo; Polyx-Oil.
He was talking about how wonderful it was and how durable it was. He said he found out when the stain on some of the paneling sections did not quite match and he had to take it down and re-stain. He tried to remove the finish but was unable so he rebuilt the panels.
Anyway, he gave me a little jar of this stuff and I tried it. It is easy to apply and appears to be a very durable finish. It has a different feel to it. It is not a slick finish like most oil finishes and it does not feel like a varnish. It does soak into the wood but it also leaves a film finish on the surface. And it did not change the color of the wood appreciably. The sample he gave me was a satin finish so it does not "shine like new money". The finish is very nice and was easy to apply but I can't say much more than that because he only gave me about 2 ounces so I don't have a lot of experience using it.
I did check into the cost and it costs like new money! Over $50 for a little less than a quart. Amazon sells it in matte, satin and gloss. A 4 ounce can is about $29.
That is all I can tell you. If I told you any more I would have to make it up.
That's a lot! The few reviews I've read and videos I've watched say pretty much the same. Expensive, but goes a long way. Teamed with one of the new ceramic coatings it can make an almost indestructible table top finish. I may have a commision for a solid walnut dining table coming up and was looking for a durable finish I can apply by hand - spraying in my shop is really difficult, especially for large projects.
The SDS indicates it's another isocyanurate cured "hard wax oil".
I've avoided working with those and cringe a little when I see people working with them without good gloves/vapor respirator in unventilated spaces. Personally I wouldn't use them without really good PPE and ventilation. Once they're cured that cooks off (more or less.. I'm simplifying a lot) so it's safe then but also partially why it's IMHO so dangerous during use.
Here's the CDC doc on the dangers of them:
Personally I think the marketing of them as low VOC (technically true) is at least misleading on the risk profile and the push towards non-professionals who don't understand the risks is irresponsible at best.
Just my $0.02. Other choices can also impose different risks and we all make our own choices...
For a low voc durable hand applied finish I've had good luck with General Finishes Enduro-Var II. I will say that it is extremely unforgiving of technique and would, I suspect, be a lot easier sprayed on. But it's entirely possible (if not especially easy) to use it as a wipe on finish if you move fast, have a really clean environment, and manage your method of application so you're not dragging on partially cured and never over apply (it's quite thin and WILL run if you put even a little to much on). Quickly applied multiple thin coats is the way to go. One the plus side it also cures quite quickly compared to most oil based finishes I've used so sanding back and re-application can be done pretty fast. Being water based the first couple of coats also seem to raise the grain a lot more (in practice I've found that lightly sanding back those actually gave me a smoother finish than when I use oils.. probably at least partially because I'm lazier about pre-finish grain raising and sanding when I do oil...).
I am not a chemist and I do not know the ingredients of Natura OneCoat.
However I have carefully researched the ingredients of Osmo Polyx-Oil and I do not think it contains any isocyanates. I could be wrong, of course. It would not be the first time. If I am wrong I would appreciate someone telling me as I have no desire to mislead anyone. I am under the impression that it is made from natural plant oils and various waxes.
Here is the complete list of ingredients from Osmo.
Full declaration of ingredients Polyx®-Oil Original Binding agents: Based on the renewable plant raw materials: sunflower oil, soya oil and thistle oil Waxes: Based on the renewable plant raw materials: carnauba wax and candelilla wax Paraffin Solvents: Aliphatic hydrocarbons = dearomatized white spirit (benzene-free) Earth: Mineral origin, silica sand, dolomite and swelling clays (argillaceous rock)The used mineral earths have been purified from all poisonous ingredients (e.g. heavy metals)and are physiologically safe. Additives: Siccatives (are obtained from the respective minerals and are lead-free) Ketoximes Polysiloxanes (on basis of silicic acid)The listed ingredients serve to regulate the drying process and to prevent film formation(5 years storage stability) and as a strong water repellent. According to EC requirements, Osmo Polyx®-Oil Original does not have to be classified or labelled and will not emit physiologically harmful compounds to environment. Osmo Polyx®-Oil Original does not contain biocides and no preservatives. The dried finish is safe for humans, animals and plants (in compliance with the German Industrial Norm DIN 53160 (resistant to perspiration and saliva) and Euro Norm EN 71.3(children's toys safety).
Well I have good news.. and (moderate) bad news..,.
The good news is that's technically correct that the OIL does not have any isocyanates.... This is true of all of the hardwax oils, the hardener is the problem with all of them (and some w
The potential bad news is that the hardener (like .. almost.. all of the hardwax oil hardeners) does..
They at least put in the disclaimer:
Use : For hardener coatings for industrial or professional applications.
Recommended use : Not suitable for household use
So if you use it without the hardener it's similar to a number of other oil based finishes but won't cure as hard as it does with the hardener.
Well, ain't that interesting. If I am understanding you that means it is a two part finish. That said, I did not use a two-part finish and the guy I got it from never mentioned that it was. So I am wondering....did it come pre-mixed as a two part finish? Is what he gave me not going to be durable? If it isn't then he is not going to be happy because he has a whole courtroom full of stuff finished with it. This is the finish that was specified by the architect that designed the courtroom.
It is always something....
It looks like they have a bunch of finishes in this line, one is a 2 part only.. this one is definitely needed the hardener:
but you're right, it looks like .. the at least the USA version of the regular Polyx high solids actually doesn't need a hardener... (I haven't verified in other jurisdictions..).
I was reading a different link SDS and I'm not .. sure if they changed the requirement (there was a bit of a kerfluffle about this a few years back which is when I got spooked by the hardwax stuff in general).
but it's also an 8-10 hour (plus) cure.. and has aliphatic hydrocarbons so.. Actually looking up the cas # on tose it appears to most likely be https://www.skincarisma.com/ingredients/11/c10-13-isoparaffin which is pretty gentle as such things go... less bad than most oil based finishes
Interesting that it also has Precipitated silica (Silica-Amorphous and Quartz (SiO2) that would surely up the gloss and hardness a fair bit..
Well, one thing is for sure, I need to learn a bit more about what I am using and extolling the virtues of. I had no intention of misleading Rennie or anyone else when I gave my opinion about the Polyx-Oil. It seems to be a good product, easy to apply and provides a durable finish although time will tell about that as I have only finished one item with it. I was particularly interested in it because of the claims of food safe contact as I wanted to use it on my Japanese style bowls and cups.
I ordered a small can which I will open and use when I next have a batch of items to finish.
I do appreciate the heads up and all the information you provided. You don't know what you don't know I always say. And, brother, I learn something new every day.
