- ABQ NM
I called home after setting up the band gear last Saturday afternoon, and LOML was nearly in tears. She'd not been having a great day, and then to top things off, the clothes dryer had stopped working. She said she noticed a weird smell and then heard a loud noise, and then it just stopped working. Knowing it was likely a belt or motor issue, I told her it was probably a relatively easy fix and not to worry about it. When I got home, I powered up the dryer. The front panel lit up, so I was pretty sure it wasn't the control board. (Whew!) Then I hit Start and could see the drum was not turning but I could hear the motor running. (Another bullet dodged.) I got online and found a local appliance part supplier that sells to the public, but they wouldn't be open until Monday. I reassured LOML that I was confident it was a broken belt and I'd replaced one years ago...it would be an easy fix.
Then I hopped on YouTube and within 7 or 8 minutes, I was basically a professional dryer repairman.
I found a guy replacing the belt on a similar model of Samsung dryer, and although it was a lot more complicated than the Kenmore I'd repaired 30 years ago, it still looked doable. On the old Kenmore, all I had to do was remove the back, fish a belt around the drum, feed it through the idler pulley, and bam...it was done. On the newfangled Samsung, I had to remove the vent port and some of the screws on on the back, remove the top, remove a heat shield, remove the control panel, and remove the front, install the belt from the front, and then feed it through the idler pulley through hole where the vent port was in the back.
After getting the top off, I tried to pull the broken belt off the drum but it was stuck somewhere under the drum. Once I got everything else taken apart, I realized that the idler pulley was not spinning and the friction from the belt had actually melted the plastic pulley wheel. The belt was wedged in the idler pulley to where it couldn't move. (It wasn't actually broken until I tugged on it.) So now I needed not only a new belt, but a new idler pulley assembly. It went from a $40 repair to a $100 repair.
Still a lot less expensive than calling someone out to fix it for me. Fortunately, the local parts shop had both parts in stock, so after a trip there this afternoon, I got the new pulley and belt in place and put the dryer back together. I also spent a lot of time cleaning 10 years worth of dust bunnies and fallen socks and other junk from behind both the washer and dryer. I'm happy, mama's happy, and all is right in the world again.
Here's the in-progress pic:
Here it is all buttoned back up:
And here's the melted idler pulley that caused the whole problem. The surface where the belt rides is supposed to be solid (like on the left of the photo), not see-through, lol:
This dryer also has a steam feature for removing wrinkles, so it's supposed to also be connected to a cold water line. Since we've only used that feature maybe 6 times in the past 13 years, I decided to not even hook up the water line. I figure it was just another potential point of failure, and I'd rather not deal with a flooded house if something were to break. If I want to un-wrinkle clothes, I'll just use a spray bottle like everybody else does.
I found a guy replacing the belt on a similar model of Samsung dryer, and although it was a lot more complicated than the Kenmore I'd repaired 30 years ago, it still looked doable. On the old Kenmore, all I had to do was remove the back, fish a belt around the drum, feed it through the idler pulley, and bam...it was done. On the newfangled Samsung, I had to remove the vent port and some of the screws on on the back, remove the top, remove a heat shield, remove the control panel, and remove the front, install the belt from the front, and then feed it through the idler pulley through hole where the vent port was in the back.After getting the top off, I tried to pull the broken belt off the drum but it was stuck somewhere under the drum. Once I got everything else taken apart, I realized that the idler pulley was not spinning and the friction from the belt had actually melted the plastic pulley wheel. The belt was wedged in the idler pulley to where it couldn't move. (It wasn't actually broken until I tugged on it.) So now I needed not only a new belt, but a new idler pulley assembly. It went from a $40 repair to a $100 repair.
When I moved back to NM, she stayed behind in CA for a while. I had bought the washer and dryer about a week before I moved. Not long after I arrived here, she was having trouble with the washer not wanting to run complete cycles, so she called a tech out to check things out. After checking things out thoroughly and finding nothing wrong, he asked her to run a typical load of laundry so he could see the washer in action. She loaded it up and pretty soon after that the washer signaled that it was done. Turns out the problem was she wasn't loading enough clothes in the washer for it to even sense there was anything in it, so it was shutting down early.
