- Constantine, MI
Or, in my case, green (I have one of the original series Rikon 18" saws, before they moved to blue.
I have a lot of veneers to slice for the bent laminations on my chess table chairs. So, this morning I took off my 1/2" blade, took off all my guide bearings and cleaned and lubed them and installed my slicer 3/4" 3 TPI blade. Got it tensioned and noticed an unusual sound coming from the saw. sounded kind of 'rough running'. I started a test cut and the breaker popped. Never happened before. Reset, try again, same thing. At each reset the time it took to pop the breaker became shorter. Lowered the blade tension - same thing. Check the motor, its hot. Not near the capacitor (that would be too easy) but around the front bearing.
So, after a trip to Menards to buy a gear puller (couldn't find the one I thought I had but haven't used in over 20 years) I got the motor out and its still warm, after an hour to cool down. Spin the shaft by hand and it definitely has a rough, not quite grinding, sound.
Off to the motor repair shop first thing Monday morning! Happy happy joy joy.
