glenn bradley
- SoCal
My bandsaw stands with its spine towards the wall. There are clamps and other items hanging on that wall. This means that it is easier for me to take the doors off when changing blades. If you have bandsaw door hinges like this.
It may just be my inherent natural lack of coordination. One thing I dreaded most about changing bandsaw blades was putting the darn doors back on. I would get one pin lined up and then have it slip off as I tried to align the other pin to drop the door into place.
Take a few moments out of your life and grind (or hacksaw) one of the pins to make it about 1/8" shorter than the other. I chose the lower pin on each door.
For me, this now means that I can hook the upper pin into the hole and swing the lower pin into position with much more poise.
