glenn bradley
- SoCal
This may be a bit of a broken record but between projects I like to make up batches of boxes and picture frames to use up scraps. If you've seen one of my threads on these in the past, you've seen this one
. After making the pair of dressers and few other odds and ends I have a lot of scrap. I gather pieces that are the right size for boxes.
I rough cut some blanks so that I have as little irregular material as possible before milling.
I have some scrap set aside that may make interesting tops and bottoms too.
I face joint, plane the opposite face, and edge joint one edge of the blanks. I then mark the jointed edge (since the non-jointed edge will get ripped off at the table saw when ripping for width) so I know which corners go together to provide continuous figure around the boxes. You can figure (no pun intended) out which pieces go where after cutting without the marks but, this is just easier.
So all milled square and cut to width. I don't have to worry too much about length since that will be taken care of when I miter the ends. You do need the blanks close to final length or the continuous grain effect gets messy.
Miter one end.
Flip the piece and use one of the stop blocks to cut a short side.
Miter the next continuous end.
Use the other stop block to cut a long side.
Rinse and repeat and you end up with a box with continuous figure wrapping around it.
I will cut the other box sides while I am already setup for it. Then on to slots for floating tops and bottoms.
Miter one end.
