I know this is getting a little tedious now but I feel like I need to finish up the thread
. I lay everything out in the hopes of getting all the pulls on with one batch of epoxy. The white chunks of high density foam (packing from something once upon a time) is to distribute the spring clamp pressure across the asymmetrical pull face.
Like so.
I joint and thickness more scrap to use for the trays.
Rip the stock to the various widths required.
One of the pulls rubbed a bit. This
mini scraper comes in really handy for this sort of thing.
I sometimes forget how many shop made doo-jobbers I use in my work. The depth gauge gets use on almost every project. The router sled is fairly task specific but does let you route things like these mirrored v-grooves and things like sliding dovetails without a lot of bother.
These will make more sense once you see the tray assembled.
I cut the tray parts at the tablesaw. I tend to just walk each box through all the steps. This does a couple of things for me. I don't get things mixed up and I can compensate for any slight variations in the boxes. I like this better than making everything a little loose so they all fit wherever; that's just me.
Fit them with a shooting board.
The tray supports get glued in as appliques. I have used
e-6000 adhesive for this for many years with good success. It holds tenaciously and remains a bit flexible so things like wood movement on larger projects are not an issue.
I ran out of my usual binding tape which has a bit of spring to it. Painter's tape will have to do.
Since the tape is the clamp in this application I just set the tray in place (and reverse it to test) to let the glue set.
Once the tray frames are cured I will add bottoms, some shellac and give everything a coat of paste wax.
