Three parts. 1 Piece is beyond my abilities. Top is attached with a long eye bolt thru the bowl and into the spindle. Hole for the eye bolt was drilled so it could be threaded in, also used non-foaming pva glue. Bottom was screwed with stainless 3" screw. Spindle was glued in with non-foaming pva glue. Linseed oil needs to dry a few days before it's put in service.
