Dave Hawksford
- Outside the beltway
I finally got a round to it. Cleaned the burl now to figure out how to pull the burl's. There is a lot of solid wood which I'm very surprised. Any idea would be greatly appreciated.
My 2cents would be to saw off the excess wood from top and bottom to make it more manageable and then slice it in half, or thirds depending on where the burls are located, top to bottom to see what the core looked like. You now have a few manageable pieces and an excuse to buy a bigger bandsaw. Burls are like a box of chocolate...you never know what your are going to find. Not all of them are beautiful. Knowing the quality of the core and what purpose you want the wood for, you can proceed to slice it to suit your purpose.
If you treat it like a normal log and quarter saw it, the result will be a cross section through the burl with curl figure radiating to the outer edge of the piece.
View attachment 105873View attachment 105874
If you flat/flitch saw it the results will range from the curl shown above to pieces with more "eye" type figure as you get toward the outside edge of the log.
View attachment 105875View attachment 105876
Ted and Jonathan pretty much covered it. Burls are nature's box of chocolates...you never quite know what you're gonna get. It looks like the middle of the log part is either hollow or rotten/punky. I'd probably start by cutting off the parts I'm pretty sure I wouldn't use, look at what's left over, and then ad-lib the rest of the way. Something like this...
